abs light question
abs light question
well just working through the niggly bits to get me car 100% got my temp gauge and headlight wipers working on the weakend the only other thing is my abs light on just wanted to know is it hard to remove and clean the sensors to check if that sorts it or is better to get a garage or someone to do it cheers
easy enough to remove the sensors, if the front are stuck tho your goosed as they have a habit of getting stuck and usually snap on removal, in the olden days there was planty of granadas in the scrappys to rob them off not now tho!
the backs are more surface mounted and only the bolt suround tends to break on them as the alloy corrodes and breaks the plastic.
steve
steve
Received 1,044 Likes
Ive had my abs light come on my car a few times and its always been the osf sensor,ever since i changed the osf hub.Touch wood its been ok for the past few weeks.I always use brake cleaner and i use a screw driver to clean the gaps between the teeth on the pick up ring.
