Can a T34.63 Make a Genuine 400bhp??
As above really, i've heard it said many times on here that they simply can't make a GENUINE 400bhp and if they get near they'll not last long..just wondered how many of you have had them up @ 400+ or as near as and how long did the T34 last etc??
Can this be got on standard cams too??
Just interested because a guy at work reckons his made 418bhp/ 398lb/ft on his saff with T34.63 standard engine etc..i'm not so sure tbh...
Chasing Radders
Doubt it very much on a standard engine......
I had that on my car Pete, Standard engine with T34 .63 and Karl said you could get around 380bhp with NO engine mods.....
I made 380 on power engineerings dd rollers, with headwork, bd14in bd10ex and only 1.5bar spike, 1.2 held.
now I'm on a STD ex and 2bar held it feels 3 times faster, should definately b 400
I'm sure martins seen over 400 on his rollers with a t34
Caraholic
This is one of my old engines, would do 12.7s quarters at 118mph, so make of that what you will as in-car power (traction was an issue). Spec was T34 0.63 a/r housing, medium port head with Mountune K2 cams (11mm of lift), which beat the shit out of the lifters, that these would need replacing every 20,000 miles .
The turbos lasted 3 months at a time....
mine did it - but it wasnt a standard engine and the t34 was upon as an annual service item.
car did make the quoted 406bhp and 410lb/ft when i had ahmed set it up but then a year later the turbo went again so got it rebuilt and got a mate to set it at 2bar and was producing 380 or 390 bhp / lb/ft.
I believe the standard engine is good for 400bhp but i reckon the turbo will have to work much harder than what mine did and that was bad enough
go for it mate - you will shit your pants
Caraholic
James, on a .48 housing aswell?? that's some going, 75k miles too, obviuosly there's an exception to the rule....
Mike,
Fair-play to that, very impressive AND impressive quarters too...
So the majoritiy of us/you would say around 370-380 is more realistic??
Surely it depends on the turbo build ? If you fitted maram shafts for example, which are designed for rallye turbo applications, such as full boost all the time through agressive anti lag, and high boost pressures, but ran that same spec turbo without anti lag and slightly lower boost pressure, then it will last longer but be specced to handle the high boost pressure.
Obviously you would need engine work to handle the higher airflow, but it should be possible to see 400hp ?
Not sure why you would bother, with DBB or billet wheel technology you can run a BIG turbo and still have the same spool characteristics as smaller ones, if i am not misinformed ?
i got 388bhp,376 lb ft on a t34.48 bd10 inlet,std head 2bar spike and 26psi at top end on harvey engine dyno.so would of thought a .63 would piss it,but with slight less torque?
