Any 200 Block experts on here ?
Whilst on track last weekend at Croft I dislodged a repair liner in my 200 block that had been fitted ages ago
Well now I think it is time for another block
My question is will a 205 block safely go out to 94mm or am I to look for another 200 block
My MKII Rs2000 runs a 2135cc Pinto 8v head and twin 45's so a well worn 200 block to me is fine but I do have 2 x 205 blocks "in-stock"
Below is a pic of the No4 cylinder
the casting in the 205 blocks are hit and miss at that bore size, more miss tbh, i ran mine at 93.5mm for a good while before it split the oe bore. could have linered it but not much point as i was fitting a differant engine.
my new engine is linered and is a 205 block but nothing at like 94mm
I have contemplated a 205 block with stepped liners out to 94mm as I have a spare "ship anchor" I will get it machined out to accept a liner then keep going ttill it breaks through to assess the possible available casting thickness
I also would prefer an unlinered 200 block and as you turbo boys and girls like em standard bore I was hoping for a Ł100 well worn 200 block should sort me out - lol
I know a good condition standard bore 200 block is a much sought after item
Found this company in Droitwich which you know will aint far from me
94mm liners a plenty so out with micrometer and dremel in the morning !
http://westwoodcylinderliners.co.uk/...cts/size/P100/
I would take it to Halesowen Engines mate, they did a spot on job of my mates 200 Block, put a stepped liner in for Ł80, and it was running 400Bhp... I'm home tomorrow afternoon if you need a hand.
Great news !
A friendly local engineer has measured the remaining metal between the jackets and the bore at its thinnest point and can machine a recess into the block deck on No4 cylinder to put a flanged liner back in.
So all may not be lost yet.
Will - small world !
You initially buy The Gimp from me
Then I buy a crank from you
You then buy my bro-in-laws 996 bike
So who's next are you gonna sell me something or have I got to sell you something this time ? - lol
... Had me worried then, I bought my 996 from a lad in Nottingham. Forgot that my mate bought Archs bike. He's still got it, great bike as well ..
I am trying to sell stuff at the moment, I have a ridiculous amount of parts cluttering up the house/garage
UPDATE
Block out and stripped
It appears there is a step in the bore but when the liner was fitted it was NOT pressed home to the step
When the liner slipped it stopped at the step
So the gap you see on my pic is the amount the engine shop (nameless at this point) did not go down to with the liner
Off to see them Monday
BUT
I did manage to get a standard bore 200 block today so in the words of Arnie - I'll be back - lol
BUT
one thing i have to ask and its a genuine question why run the bore so big ? are the gains from the few ccs really worth running a block so close to edge of the bore ?
not a dig in anyway i just cant see the gains can be worth it ?
i had a 205 at 1mm oversize in a cossie at 350 bhp and that did 20k+ abusive miles and was fine. i think the cc was 2050cc at +1.
Last time on the rollers it managed 215 bhp but to be fair that was on an old skool Sun rolling road so not really very accurate
but here is a video to let you hear how it sounds
http://www.youtube.com/watch?v=yZTz7XlcV-4
Just had my replacement 200 block back after being chemically stripped and checked for cracks
Off now for machining to 94mm and retest to check block not porous after boring it out
West Wood Liners are not too far from me
I am going to use one of their flanged liner to repair my original 200 block
Hopefully my new 200 block will withstand the 94mm rebore without the need for any liners
years ago i spent many days of my youth building pintos, and trrying to get them as big as possible, they end up wafer thing at much over 93.5mm in the most case, its not a case of if, more a case of when its going to fail.
A very good friend of mine ownes a machine shop, hence we know what works and what doesnt. though it usually me who takes on the r+d. hence my new engine has four liners, non stepped (though this bit is not an unknown quantity) but with a differant bore/rod ratio.
I have access to my mates Cincinatti or Haas CNC and the block is going on one of them tomorrow
Have took 205 blocks out to 93 mm with no probs before
200 should take 94 mm but who knows till later !
I ran my turbo 205mm block at 93.5mm for about 3 rally's and then it split (not due to the block i might add-was hydraulic'd ) with the test miles and set up miles including the stage miles it probably did about 5k miles all in all, and that was balls out every time it was used.
when we looked into the block thickness there was very little.
decided to then rebore another, was happy with it till my mistake, put the spare on the borer and went through, even though the previous block was ok.
its just luck tbh at how good the casting thickness is.
Collected block today and all appears fine after boring to 94mm
Decided to allow an experienced engine shop do the boring and the operator said that when cutting a bore and the wall goes thin the "note" of the cutter alters and he didnt hear anything to worry about whilst machining my block
Lets hope it all holds together this time
To understand the different noises when machining takes the kind of skill that only comes with experience and the guy that bored my block had a few years experience under his belt and he certainly appeared to know what he was on about
Need to dummy build the engine now to find how much to deck the block by to get pistons flush when on TDC
