Who can solve this problem?
Old 04-06-2010, 03:21 PM
  #41
Psycho Warren
Carbon Crazy
Psycho Warren's Avatar
youd be surprised at how often you can use pythagorus in daily life if you want to Used to use it loads when at sea on the periscope for calculating range of ships, closest point of approach etc.
Although you do simplify some equations to do them in your head so not 100% accurate.
Old 04-06-2010, 03:37 PM
  #42
whybee
prozac user
whybee's Avatar
yep, its official, i now feel very very dumb
Old 04-06-2010, 03:40 PM
  #43
DanW@FastFord
Spelling Club King!
DanW@FastFord's Avatar
Do the military not have a 'gadget' to do it for you?
Old 04-06-2010, 10:49 PM
  #44
Psycho Warren
Carbon Crazy
yes dan we have combat computers with algorithms but doing it in your head is often quicker and just as accurate despite modern computers. Plus you have to know and be well practised at doing it manually incase the computers break!!
the more information you give the computer, the more accurate its fire control solution but the element a computer cannot take into account is human judgement and experience from seeing ships behave in the past and how things change etc.
its not all that complicated. its pythagorus and speed time distance calculations.
Old 04-06-2010, 11:24 PM
  #45
botters
competant bodger
botters's Avatar
my brain hurts
Old 04-06-2010, 11:28 PM
  #46
mrjenrst
mrjenrst's Avatar
I'd be suprised if anyone wanted to freely use it in daily life tbh.
Old 05-06-2010, 12:16 AM
  #47
Saaamon
Saaamon's Avatar
Originally Posted by DanW@FastFord
You did that shit for fun???
Old 05-06-2010, 01:24 AM
  #48
Psycho Warren
Carbon Crazy
Youll find it quite useful if you learn it by heart and learn most of the sines and cosines in 5 degree angles and the common answers to speed distance calculations.
If your quick you can use it almost autonomously in driving to work out time to next junctions, clearance distances when taking quick overtakes etc etc.
Simple example is overtaking. If you reasonably accurately estimate the speed of an oncoming vehicle, accelearation rate of your vehicle, distance to the oncoming vehicle etc you can estimate the time and distance you have to overtake a car safely based on the oncoming vehicle you can see or the next blind corner/safe distance you can see. Obviously you err on side of caution. But with practice you can do it as quick as normal distance judgement will tell you and it gives you a mathmatical "bollocks check" compared to what your judgement may say is a safe overtake.
Old 05-06-2010, 01:45 AM
  #49
STAFFY OWNER
STAFFY OWNER's Avatar
And by the time you've taken all that into account the gap has gone and you've missed your overtaking opportunity .
Old 05-06-2010, 02:37 AM
  #50
Psycho Warren
Carbon Crazy
depends how crap your mental arithmatic is if youve already got the figures in your head then you know the answers and just fit the picture you see to an answer which matches in your head then estimate the difference between!!
Old 05-06-2010, 11:43 PM
  #51
fraser9764
fraser9764's Avatar
read this last night and for some reason was thinking about it thismorning while eating breakfast,
easiest way i could think of was,
using 10 for the baseline as it can be anything, and each side is proportional to its vertical so it works out at 6 and 4 again.
can also be done/checked working from the opposite side triangle
Old 06-06-2010, 01:58 PM
  #52
alistairolsen
alistairolsen's Avatar
Yeah, normally several ways to skin a cat. Triangles have me thinking trig and pythagoras and like Warren says, when you use it all the time, both in real life and in work its not hard to do.
Worth the working to get the formula if you had to do a few different ones, but then if i had that many to do Id set it up once in a spreadsheet and drag down :P
Old 06-06-2010, 04:19 PM
  #53
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Autocad told me its 2.4 & i need no more calcs to prove it.
Old 06-06-2010, 06:28 PM
  #54
scoooby slayer
scoooby slayer's Avatar
i wouldnt have a fecking clue, but when you look at the height of the 4 mark side its 57mm high, and the x mark is 34mm high so 4 / 57 x 34 = 2.385.
i have no clue about algebra as to what it is or what it means but thats how i got the height of x.
DAZZER
30-09-2015 08:43 PM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
dms04
11-09-2015 01:57 PM
Quick Reply: Who can solve this problem?
