what type of facet fuel pump for pre swirl pot
16-05-2010, 09:13 AM
500bhp Cosworth in making
i know facet do different kind of pumps. i need a lift pump to supply a 2L swirl pot on my cossie. which type do i use?
thanks
16-05-2010, 09:20 AM
Don't need a lift pump , I use a STD pump in my 205
16-05-2010, 09:21 AM
so i can us a std cossie pump to pre pump and 044 on main pump?
16-05-2010, 09:25 AM
Quote:
Originally Posted by
Roosie
That will be fine depending on power output.
16-05-2010, 09:45 AM
cossie pumps gravity fed so be careful how its all mounted roosie, we use twin Facet Red tops, some people use a singlr Blue Holley
The twin facets feed a 1 litre swirl pot then that feeds a 044
at moment just keeping to about 500bhp or shall i run 2x std pumps to feed engine
16-05-2010, 09:48 AM
Jasesapphy
thats what worries me as i havent got a spare wheel well anymore so everything will be on the same level.
16-05-2010, 09:57 AM
we had fuel issues last year on the track car as we tried using a standard pump, the cost of red tops are cheap but they are fooking noisy
16-05-2010, 09:58 AM
16-05-2010, 09:59 AM
Jasesapphy
i think noise of the pumps will be last of worries with a GT35 (Screamer pipe) and twin side exits on 4" bore
16-05-2010, 10:00 AM
16-05-2010, 10:01 AM
why have you linked the 2 facets together wouldnt it be easier and better just to supply the swirl individualy
16-05-2010, 10:03 AM
would be a lot better if we could but we already had the swirl pot, may change at some point but we are only running baby power buddy, so more than enough for us
16-05-2010, 10:05 AM
ignore me it looked like it had to peices going to the swirl from both pumps but its a cut odd hinding underneath that will be going to main pump
16-05-2010, 10:14 AM
Roosie
If you are using a gt35 then your high pressure pump is going to be at best marginal never mind the low pressure side
martysmartie
06-09-2015 10:22 AM
mint_s2
02-09-2015 08:58 AM
jonjg
01-09-2015 03:46 PM
ekjim
27-08-2015 05:20 PM
Prickly_buzz
25-08-2015 11:33 AM
auto ,
facet ,
fuel ,
gold ,
lift ,
pot ,
pump ,
pumps ,
red ,
swirl ,
swirlpot ,
top ,
type
