Changing Subframe ?
Old May 15, 2010 | 10:05 AM
Tazz88's Avatar
Tazz88
Summer time Fezzy RST :D
Default Changing Subframe ?
Changing a subframe. This will be the 1st time but isit something i can take on or should i get some help take it down to my local garage to fit it for me ?
Old May 15, 2010 | 10:15 AM
vaughant's Avatar
vaughant
Yeah,if you've got the tools it's not a bad job at all.obviously it depends upon what car your working on but the priciples are basically the same.what car is it on?
Old May 15, 2010 | 10:43 AM
Tazz88's Avatar
Tazz88
Clio. I have the tools i think it should just be normal sockets & bolts ?
m4tt274's Avatar
m4tt274
shouldn't be to bad i wouldn't have thought
Old May 15, 2010 | 10:46 AM
Tazz88's Avatar
Tazz88
I will probably call my down to help me lol
Old May 16, 2010 | 12:11 AM
vaughant's Avatar
vaughant
Done one before,very easy,u need 16mm socket from memory as that's the general bolt size so double check as not all sets have them.it was easier to unbolt the steering rack from the frame iirc as I'm sure the pinch bolt for the column was inaccessible.there was a rear engine mount that needed undoing but it was generally pipsish.be careful that the whole thing dosent swing at you when you take the last bolt out as it did for me and gave me a nice whack on the nose!!!
Old May 16, 2010 | 11:06 AM
KW-rscos's Avatar
KW-rscos
Should be easy enough, I had to lower mine when working on my old escort, didnt have to remove it completely but it was easy enough if I needed to, just undone all the bolts and lowered it with a jack.
Old May 16, 2010 | 11:14 AM
Tazz88's Avatar
Tazz88
Ohh ok. I'll rather learn & do it myself/help from mates then to take it to a garage. Last time i eneded up paying something like £400 but that was including new brakes but on top of that it took them 2 weeks to locate a subframe
Old May 17, 2010 | 10:15 AM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
We'll sort it
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
