what do i do?
I think you should stick the hose pipe up your arse hole and not turn it off until its up to your eyeballs!
Maybe then it will flush all the shit out of you, and you can come back here and start again.
so you've been reading this thread
https://passionford.com/forum/genera...il-inside.html
and thought you'd come up with your own fail thread.
i'll say one thing...pic's or it never happened
it siezed enit coz u had no lubes blud the engine is air now so wieght it in enit fill it wid the nicked fridge freezers an make sum p enit den buy a draw and forget the problems
translation you have probably knackered the engine because you was a muppet and run it with no oil so it had no lubrication and you shouldn't own a car if you did not realise that would happen
fill dems engines with bare oyl and sand blood den you need to bump dem tings down the road get me? be show to fill it rite to tha top tho seen, if it dont work like straight away keep trying rags! lowe that man standard.
Fill it full of sennacot, that always unseizes me! Never fails. But if it dont work, tie your hoodie strings to the cam pullies and keep cranking it till something happens
and i know yeah we drained da oil out an that an da machanic sed i needed 2 flush the engin oyl out when i changed da oyl so me an ma m8 went to change da oil so we undid da sump thing an da oyl drained out but we cud stil see sum oyl in da engine so ma m8 fired it up an got da hose an flushed it out an it wa fine. den we put new oyl in it an when we started it up it wunt start an ma neybur said it seezed
if u rev limiter it then dump da clutch a zetec does 0-60 in like 5 second but dey didint do dat in the road test cuz they think it wud damage da engin so dats y i want da 2.0 cuz dat will be well quick hopefully
im so pissed off at ma sen for rekin my engine it wa sweet aswel
cant belive this nob is still on this forum!
mabey phatford is d4?
ffs mods give us all a break and ban this idiot.
i come on here to give advice where i can and for advice and i have to look at threads by this inbread window licker.
phatford, to sort you engine all you need to do is get in the boot and get one of your "bruvs" to weigh it in!! SAFE
Sounds like another chav off the road
fml, so let me get this straight. You and your 'hommie' changed the oil in your car and when you could see some of the old oil* still on the cam lobes you pushed a hose pipe into the engine and fired it up until it was clean, and then are asking us why it Seized*
you are why god invented the 9mm
