FAQ waterbase painters
10-05-2010, 08:08 PM
iv start using waterbase paint with a 1.3mm setup an i seam to be getting dry spray alot? whats the cause of this?
10-05-2010, 08:39 PM
what pressure you spraying at?? i'm on a 1.3 an spraying at 28-30psi. (i think..lol)
also what kinda gun?
10-05-2010, 08:55 PM
Pretty sure i'm running a 1.3 setup on a gti pro. Spraying at 2bar. What paint you using and whats the thinning ratio?
10-05-2010, 09:05 PM
its lesonal paint, the man give me this little bottle of clear stuff to mix with it an said you dont thin it?
10-05-2010, 09:06 PM
Quote:
Originally Posted by
cossie690
2 bar mate, its a upol spray gun?
10-05-2010, 09:07 PM
That clear stuff is probably your thinner then i guess. Hard to say why then.
How are you applying it, cos you can proper lay it on, not like solvent
10-05-2010, 09:10 PM
were on standox at work. it's thinned to roughly 10%. it's pretty lumpy to spray if it aint thinned down. the standox stuff is thinned down with demineralised water. might be worth trying to thin it.
10-05-2010, 10:45 PM
xr_craig
iv been dusting it on so thats the cause?
10-05-2010, 10:58 PM
theres your issue mate, i usually give it a light coat, 2 wet coats then a drop coat. Giving each coat time to dry between.
Also some people like to drop coat while its wet but in my experience it doesn't really matter
Dave Henshall
08-12-2006 11:53 PM
Stu @ M Developments
14
06-11-2006 07:37 PM
PassionFord FAQs
25-11-2005 12:08 PM
Paul_Painter
03-10-2005 12:38 PM
Gizmo
14
19-08-2004 09:15 AM
