diagnistic code readers?
Old May 7, 2010 | 04:41 PM
diesel's Avatar
diesel
Default diagnistic code readers?
im thinking on buying one but dont know anything about them or have never seen one being used, are that easy to use?
are the universal ones any good? if i was to buy one i would only spend about £100 max and could i get a tidy one for that?
any advice would be great plus what one would you recomend for that type of price
thanks diesel
Old May 7, 2010 | 05:17 PM
foreigneRS's Avatar
foreigneRS
Testing the future
very easy to use on most vehicles - just plug in to the universal OBD port and off you go. have a look on here:
http://www.e-diagnostics.co.uk/
Old May 7, 2010 | 08:40 PM
diesel's Avatar
diesel
n1 mate do most common cars use the same plug or is every make (ford vauxhall etc.....) use different ones?
Old May 7, 2010 | 09:03 PM
CBenno's Avatar
CBenno
Yer most modern cars use a 16 pin plug older cars have all sorts of different shaped and sized plugs
Old May 7, 2010 | 09:35 PM
foreigneRS's Avatar
foreigneRS
Testing the future
the clue was the use of the word 'universal'
Old May 8, 2010 | 05:57 AM
diesel's Avatar
diesel
lol universal means nothing when your buying from ebay you should know that thay will sell anything everything is universal lmao
Old May 8, 2010 | 09:12 AM
vaughant's Avatar
vaughant
Hi mate,I use a mac tools one,cost me£90 from the rep but he dosent do us any favours so that should be about right.it should work on any car post 1996 through the obd2 port.It's an amazing tool,so handy my one reads codes stored even if no eml on,it can erase them as well which some cheapy ones can't,the only car I've had trouble connecting to is my 1998 corsa which apparently is a problem even for the big machines as you can often only connect them upto a vauxhall tech 1 unit.I was told it wouldn't work on vws as they use a different connector but that's total crap,it works everytime on them.be aware though that it can sometimes only give you a generic fault like on a Clio this week we've been doing,single cylinder misfire,cylinder not specified,how handy!!if u haven't got one,get hold of an autodata cd,pm me if ur stuck,as this gives u obd connector location points,fault code explanations etc,wiring diagrams,component locations so it all ties in nice.in fairness it got the Clio down to an injector wiring fault which turned out to be a tiny break in the loom up by the multiplug,we changed coilpack and one injector as well which cleared three of the faults but it still came up with the wiring problem which I was very impressed with,re soldered and all was well!!
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
Si B
Sep 12, 2015 06:49 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
