zetec camshafts - 1.8 cams in a 2.0? help please
ApplicationPower BandCam Lift(mm)Valve Lift(mm)DurationTimingFull LiftVC (mm)LTDCRequired PartsSports1500 - 6500I 10.08 E 9.34I 10.08 E 9.34262 Deg21/61 61/21I 110 Deg E 110 Deg0.00I 1.22mm E 0.91CF52 / VS46Part NoPart TypeDescriptionFZ1801CamshaftSports got a pair of these fz1801 cams for a zetec - bought them to go in a 2.0 black top zetec - turns out there for a silver top 1.8 .... would these make any diffrence in the 2.0? what is the diffrence in silver top/ black top (hydraulic / solid lifters) camshafts - i cant see a diffrence?
I don't really understand what you wrote but...
Kent fz801 cams are practically the same as standard silvertop 2.0 cams essentially they are the same as the 130 spec setup.
I don't know if they will fit in a blacktop and if they do I think they would be the same as standard.
grishenko45
09-09-2015 01:58 PM
