Little black box on top of Gear box
Old 07-05-2010 | 10:07 AM
maverick1984's Avatar
maverick1984
Default Little black box on top of Gear box
Morning all,
I have a 1999 1.8d escort van. I changed the Gbox oil in it yesterday but only managed to get approx 2 litre in through the filler/top up hole.(Hayne and owners manual recommend approx 3 litres??)
I looked through the top of the engine bay and on top of the gearbox there is a little black box. When i took the lid off i saw a round whole. I put the engine oil dipstick in there and it went in approx 3 inches before i hit something.
Can i top up the gearbox fluid through this hole?
Old 07-05-2010 | 02:11 PM
maverick1984
some said it might be a breather box - do you think thats correct ?
Old 07-05-2010 | 02:13 PM
alexno1dj's Avatar
alexno1dj
that is the gearbox filler mate
Old 07-05-2010 | 02:14 PM
alexno1dj's Avatar
alexno1dj
it does also serve as a breather
Old 07-05-2010 | 03:03 PM
maverick1984
Thanks chaps - just need to find a funnel or a tube to fit in it now.
Old 07-05-2010 | 03:35 PM
phil_focus's Avatar
phil_focus
how much oil were you able to drain out??? because if it takes 3 ltrs and you only drained out 2 then you have 3 lts in there now!!!
Old 07-05-2010 | 03:55 PM
maverick1984
Well i managed to drain approx 2 litre and i managed to get in approx 2 litres before it started to come back out the fill hole. i filled it through the prober fill plug not the black box. i am only going to top it up very slightly trough the black box but its handy to know its thre as it will save me jacking up the car etc in future.
Old 07-05-2010 | 04:28 PM
xr4x4rs's Avatar
xr4x4rs
that black box is not a fill hole its a breather
you fill to where you said you have done it until it comes out then its at the correct amount
you will not get all the gearbox oil out unless the box is off and and tip it up
if you fill into that hle you will over fill the gearbox and it will spit out everywhere
the gears dont need to be fully emerged in oil, there like a crank where the bottom of the gears sit in oil and when turn pik the oil up to lubricate the rest of the box
TrevCos
Alloy wheels and ICE for sale
13-09-2015 03:12 PM
matman
09-09-2015 06:45 PM
ekjim
17-08-2015 09:57 PM
track.focus'd
12-08-2015 06:53 PM
xr_craig
07-08-2015 07:00 PM
