cosworth ignition amplifiers
abdr500, I didnt say ALL were compatiable from the Fiat range.
You are wrong it is NOT a PURE cossie item.
The weber IAW injection system is a "customer" system that was supplied to many
vehicle manufacturers not just Ford.
Originally Posted by abdr500
your all wrong as i tried one off a uno turbo and they look the same but didnt work so its a cossi item
BUY A NEW ONE - trust me , do not mess with used ones when doing this conversion , i had a used unit , worked fine in the normal dizzy setup, in fact i run it to test it on stu @ MSD's car , ran fine, when setup to run coil pack i only had two cylinders running , now weather this was just bad luck or there was something about the coilpack setup that only uses a certain part of the amp that the std dizzy setup doesnt use i dont know , but it had me and kenny scratching our heads for a good few hours , in the end , brand new amp ( MSD have them in stock ) same wiring , fired on all 4
dont scrimp on parts that you will rely on - trust me - lesson learnt !!
PassionFords Creator
markk,
worked fine in the normal dizzy setup, in fact i run it to test it on Stu @ MSD's car , ran fine, when setup to run coil pack i only had two cylinders running
Only a Knight Industries vehicle would show such a fooking error though im sure
Stu @ M Developments,
That was fooking confusing...
too true m8 !!!
im coming across this afternoon , so get the kettle on , must be your turn !!
One thing that is ESSENTIAL is good earth wiring - the ignition amps are very sensitive to interference on the trigger inputs, and a "good" source of interference is poor earth connections on the engine system loom, with interference being generated by . Cossies are pretty marginal on this front at the best of times, and anything less than how it should be is likely to cause problems.. how many cossie owners haven't seen that erratic tacho activity..? that is due to ignition amp trigger interference.
In a borderline case, changing the amplifier often appears to remove the symptoms of a problem, but in fact it may well be just masking the problem of a poor earth connection, by being able to operate at slightly different trigger signal thresholds.. I've heard a few instances of people trying a "duff" amp on their mate's car and it works perfectly, and vice versa..
Richard, you are quite right.
The reasons for this...... (for others as Rich is a clever chappie)
The problem is multipole earth connections needed for proper running.
As the ECU voltage is taken from the engine inlet manifold and the ignition main
earth is taken from the body work.
This generates a voltage differential of around 0.5 to 2.5 volts
(high frequency noise) while the engine is running.
These can ONLY be measured using an osciloscope.
The result is a virtual ground shift which ends up in false input triggering.
As these connections age or work loose, this can cause "marginal"
mis-firing problems.
Is a Cosworth Ignition module the same as the ignition amplifier? (reason i ask is i told someone i know that had symptoms of a duff ignition amp/bad earth to check theirs and they said it was "one of the ignition modules" didnt know what they meant by that tho.
Simon is it better to have an earth for the amps, as close to the amps as possible then?
rather than where they are on the inlet?
As you know i've made a custom loom, but not finished yet, and earthing is something i want to make spot on.
As you can never have enough earths on a ford.
What do you suggest?
Ryan, NO..
The earth on the inlet manifold is JUST for the ECU - NOTHING ELSE.
The ignition modules MAIN power comes from a bodywork earth wire.
(E.G. On escort cossie this is bolted on inner wing near original coil)
The ignition module ALSO sends an EXTRA earth to the ecu pin 24.
This is the trigger earth and must NOT be used for anything else.
THIS IS very important that this is wired like this,
ok mate, cheers, and the opposite for me wanted to build mine on a late saph or 4x4 one, but this i what i had available and what the looms going in.
Just checked, as i have the 3dr loom untaped, and yep, 3 earth go to the inlet, Amp, and 2 ECU earths
Simon, I think I'm right in saying 4x4 coil/amplifier earth terminates at the plenum too... I've soldered in an extra local one, out of the amplifier connector. Like you, i've spent a lot of time with an oscilloscope discovering how crap they are!!!
03-11-2015 04:08 PM
