Prepping a Car for Spraying
so lots of answers then
no ones actaully said what makes a good prep yet.
but you all seem to know the obvious.
same as everything. The key to a good finish is a good preperation
anyone knows that
BUT HOW DO YOU GO ABOUT DOING IT
anyone knows that
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
well it depends on what ya gotta rub down really lol!
i assume ther eis no filler to!
So just scotch bright everythin to fook!
as your just gunna b goin over the old paint!
Give the paint a good scotching to give it a key, make sure it's all clean and wiped down after and there are no bare metal areas, if there are, use an acid etch primer on them straight away, then rubb that down smooth.
Make sure the body shop has no objection to you doing this basic prep work, some get funny and will still charge you the full amount as they will claim they need to go over your work.
a friend is spraying the car, and doesnt want the hassle of prepping things like underneath neath the car and the engine bay and inside the car.
Basically the car is being sprayed everywhere is lovely ford diamond yellowish white
Inside, Outside, Underneath, Engine Bay
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
When you have found out you can come round and finish mine for me!!
Please give me a call as I would like to discuss if your "mate" wants some more work and have you found those hose's?
nope sticking with ford white, might aswell keep it original colour.
Glacier white has got far to much blue in it IMO
Its got more blue in it than diamond white has yellow
Don't rub down wet, always rub down dry to avoid moisture getting caught under the paint, as said previously 3 days rubbing down and 3 hours painting will always look better than 3 hours rubbing down, 3 hours painting and then 3 days cutting back to a finish. less elbow grease aswell
yeah i intend to take day's even a couple of week's just getting everything perfect for spraying.
As you say abuser, i've been advised not to wet & dry, and to use anything above 240-400, then work through the grades, scotch brite everything, and make sure everything is keyed and clean
rog
04-09-2015 12:10 PM
track.focus'd
12-08-2015 05:53 PM
paceo
12
04-08-2015 08:50 PM
