Any TV experts in here?
I have had my 42" rear projector for about 8 years now and its time to get a new Tv so the other half has said she's up for it so we are going to go halves.
I have pretty much decided on a panasonic TX-P42G20B
http://www.panasonic.co.uk/html/en_G...557/index.html
but i have a little niggle in the back of my mind about the new LED tv's. Does anyone know much about them should i be looking at them or is the one ive chosen the better option.
ta
ta
http://www.cramptonandmoore.co.uk/
i could perhaps get it a little bit cheaper but there that close to me id rather just go there,
That's an awesome price from costco - much to my disappointment when it's lower than 1st line distribution trade prices!!!
Eagle - you'll struggle to get big discount cause the margin simply isn't there. Consider what you're getting in terms of tight-tolerance, high-precision engineering for under a grand and compare that to what people regularly pay for something as simple as a set of bedroom furniture. And then consider that the retailer has to support it if it breaks.
Chris
Chris
ta
ta
I may be wrong, but most of the current affordable crop of LED TV's are only lit by LED, not true LED so not really sure they are worth it just yet.
funnily enough my little bro just bought one of the tvs the OP has mentioend. VERY nice telly... and on the point of nto going to big stores, i accompanied him to comet only to find 2 very similar panasonic tvs (one was a slightly older model than the other) with the newer one obviously priced a little higher.
this seemed justifiable when looking at the picture quality of the 2 sets, but according to the specs they were the same internally with just a slight external restyle.
turned out the difference in picture was probably somethign to do that the newer one was being fed via hdmi wheras the older one was being fed using regular coax into the aeiral socket! not impressed!
Can't say I've ever done it with anything other than my eyes either - business hasn't been going long enough to warrant the expenditure on the kit and courses in all honesty! Ultimately you're watching it with your eyes, not a calibration camera!
Out of all the discussions I've had with other installers, ISF seems to be the preferred standard/method from a results perspective. I would guess that it's possible to calibrate a screen to fit isf and thx profiles at the same, just not ideally so for both? :s
Bought a little LG monitor for basic test purposes the other day actually (smallest and cheapest full HD monitor I could find @ ~£160) - I was pleased to find it actually has a pretty full range of calibration settings, to the point where it's quite easy to get a £300 picture out of the £160 tv Good times!
Thats looks very nice indeed.
I see Sky are doing a free HD box and setup until June 10th so ill make sure i get it sorted by then.
DavidK
27-09-2015 02:55 PM
puntoturbo
04-05-2005 02:10 PM
