Focus RS & Focus ST170 rear Disks
Right the handbrake cables feeding the drivers side rear caliper is sticking, first questions is. Are the RS and ST170 cables the same? and 2 is there any way of lubricating my sticky cable before shelling out for a new one which is probably expensive because you have to buy both sides
RS, ST, And any Focus with discs all use the same calliper, so the calliper end fitting is the same.
RS and ST use a slightly larger diameter disc so the Ford listed cable is probably slightly longer, but an after-market one is likely to be long enough to do all.
track.focus'd
12-08-2015 05:53 PM
