Should the fuel pump prime when the ignition is switch on?
This is for poeple running a 2.8 MFI like a xr4i etc
I have a old tvr with the above engine in and its noe been starting that well with out giving it some right foot, i noticed the fuel pump only runs while cranking and doesn't purge when you turn the igniton on,
is this right or not is the question?
cheers steve.
cheers steve.
3dr Cosworth owner
same system as the old 3i's. It should prime until it gets to a desired fuel pressure mate. Had loads of trouble with one of my old 3i's. Turned out to be a relax under the dash. Mine was pink
I have been told there is a relay that just controls the fuel pump priming so now ive just gt to find which one it is
has anyone got a xr4i that know the part number or even just the colour.
Series1guy was your relay in the fuse box or was it a loose one?
3dr Cosworth owner
Yes I meant relay lol, cant see what im typing when using the phone so its guess work really lol, Mine was a pink relay in the drivers side footwell area not in the fusebox under the bonnet.
Cheers i thought if it was in the fuse box it is pretty likely tvr have left it there but if its a loose one they could of put it anywhere i have a light green i think relay hanging about in the engine bay all by its self i was hoping i was that one
Hi Mate,
Just a note to say that the pink relays are the same for 3i, capri, 4i and RS Turbo's.
Pink as standard colour but some aftermarket ones may be black. Some relays prime after ignition on but some don't I have noticed. If your fuel accumulator is working then system pressure should have been maintained anyway. Ifd not it only takes a second to build up pressure again.
JK12
33
26-04-2021 12:09 PM
jonfoc
16
11-09-2018 05:35 PM
