low or high independence injectors
hi
i got a set of siemens blacks 850cc injectors which i use to run on my fiesta turbo live mapped on a L8 ecu, would they low or high independence injectors, would live mapping a L8 ecu enable you to run both low and high or that has no bearing..
thanks
sean
thanks
sean
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Hi Sean,
If they are the 83lb Siemens ones MSD supplied then they will be low impedance as they are the correct ones for the L8.
Hope you're well mate?
