Sponsored by:
Sponsored by:
H.Engineering, F.Motorsport, Hub Dyno
Old 21-04-2010, 08:13 PM
pauljh
pauljh's Avatar
Thumbs up H.Engineering, F.Motorsport, Hub Dyno
I took the car down to Torque Developments today, nice bunch of lads and tested my winter mods.
Spot of Harness Engineering kindly supplied the additional sensors required and sorted out the wiring for all the toys and made a top quality Engine Harness for me, Tom Field of Field Motorsport configured the T62000 ecu for me and mapped the car today, both very proffesional, a BIG thanks guys.
I rebuilt the engine about a year or so ago and modified the car for boot mounted rad etc to fit a huge intercooler in the front when i stepped up to a much higher spec rebuild, it was running on P8 previous to this.
The following graphs are power at the wheels.
1.6 bar boost
2.2 bar boost
1.6 bar and 2.2 bar overlayed
I think i am going to have to be carefull in my car!!!
Where's the toilet paper.
Old 21-04-2010, 08:18 PM
andyc83
andyc83's Avatar
how much does it weigh?thats going to be mental!!
Old 21-04-2010, 09:46 PM
pauljh
pauljh's Avatar
About 780 KG full of fluids.
Old 22-04-2010, 06:58 AM
foreigneRS
Testing the future
foreigneRS's Avatar
see you in hell you fucking nutter
now can we talk again about which is faster - cars or bikes?
Old 23-04-2010, 12:28 PM
pauljh
pauljh's Avatar
Hopefully i will avoid Hell, i just need to get the traction control working properly!
Old 23-04-2010, 12:36 PM
R4N SS
R4N SS's Avatar
mental
Old 23-04-2010, 03:43 PM
scoooby slayer
scoooby slayer's Avatar
my god 600 atw and under a ton
that thing is gonna be crazy quick
is it rwd ?
Old 23-04-2010, 04:33 PM
pauljh
pauljh's Avatar
Yes, Rear wheel drive.
Old 23-04-2010, 04:34 PM
stu21t
stu21t's Avatar
is this right,
756bhp per tonne at the wheels
holy shit.
any vids of this?
Old 23-04-2010, 04:40 PM
rsnissan
rsnissan's Avatar
is it nippy like?
Old 23-04-2010, 04:49 PM
andy escos
andy escos's Avatar
fooking madness but i like it can you put up the spec sheet for your car to see what you have done
Old 23-04-2010, 04:51 PM
pauljh
pauljh's Avatar
No, Horse power per ton is calculated as follows;
1000 (1000 KG=ton) divided by the weight of the car in KG
Multiplied by the horse power (normally crank horse power)
Therefore 1000 divided by 780 =1.2820512
2wd transmission losses would be at least 10%
Therefore 591 wheel HP X 1.1 = 650 crank HP minimum
1.2820512 X 650 = 833 BHP/Ton
The same works for torque
460 X 1.1 = 506
1.2820512 X 506 = 649 LBFT/Ton
Hope this helps.
Old 23-04-2010, 05:01 PM
stu21t
stu21t's Avatar
i just typed bhp per tonne calculator in google,
and it came up with 768
whatever it is its bloody impressive.
and wouldnt rwd tranny losses be more like 18% making it 696 at the fly?
madness.
vids?
Old 23-04-2010, 05:02 PM
pee vee
pee vee's Avatar
jesus fukkin christ! LOL
Old 23-04-2010, 05:10 PM
LHD220Turbo
LHD220Turbo's Avatar
that is madness, wouldnt fancy it in the wet mind
you've got to take that to combe this year!
scoooby slayer
i take it youve got launch control ?
my god it must be insane to drive rwd !
Old 23-04-2010, 05:51 PM
pauljh
pauljh's Avatar
Yes,
I have launch control and traction control on the T6, it has some base settings in it but iassume it will take some setting up. I had a Racelogic launch/traction control system fitted previously.
I am unable to drive the car until the suspension is checked and set up as i have also changed the suspension and have some issues, hopefull that will be sorted in a week or two.
Old 07-05-2010, 08:51 PM
pauljh
pauljh's Avatar
Default Engine Spec
Engine spec,
Cylinder head.
26.5mm line bored inlets
25mm exhaust
3 angle valve seats
balanced chambers
Above works carried out by Niel Roper
double valve springs
Standard Cosworth inlet and exhaust valves
Arrow solid lifters and shims (supplied by Steve)
Piper 651 cam shafts (timed at 110 degrees full valve lift on inlet and exhaust)
Piper verniers
Turbo/Exhaust.
Tubular inconel exhaust manifold (Metalogic)
Pro Gate 50 waste gate
GT35R with .82 housing
3" exhaust system
Block.
200
6 long studs
4 short (ARP)
Coopers rings
Oli squirt jets
Windage plate
Flap type sump baffle
Cosworth oil pump
Crank.
Knife edged, polished & balanced
Lightened 2wd fly wheel with ARP bolts
Above works by Mike Jennings
Rods.
Arrow (supplied by Steve)
Rod bolts Arrow (as above)
Pistons.
Cosworth, decked and pocketed (by Joe Stevens plus general advice for assembly)
Cosworth rings
Electronics.
T62000 (configured by Field Motorsport)
Launch control
Traction control (in car adjustable)
Water injection
Boost (in car adjustable)
Air injectors
ALS
Distributorless
36-1 crank pulley
Raychem loom (Fabricated by Harness Engineering)
Fuel pressure sensor
Oil pressure sensor
4 no wheel speed sensors
Fuel,
1000cc injectors
WRC bosh type fuel regulator
Twin Bosch pumps
Lift pump & swirl pot
Miscelaneous.
Swedish type inlet manifold
Intercooler
Rear mounted rad
Header tank
Water swirl pot
Fuel swirl pot
All fabricated by Richard Jones Motorsport
70mm throttle body (R&B Motorsport type)
More recent picture of engine.
Pictures of engine pre assembly.
Old 07-05-2010, 09:03 PM
Rab
Fucking superstar........
Rab's Avatar
Holy fucking shit! How long do you think you'll live????
Old 07-05-2010, 09:16 PM
pauljh
pauljh's Avatar
If i can get the traction control working properly hopefully for some time yet, i was running 605 bhp & 436 lbft before on P8 with a Raceloic traction control system, the tc system worked very well.
The tc and launch built in the T62000 should work better with less power loss, i just need to get it set up properly and learn to trust it as i did the RL tc system.
I had a very quick spin further to replacing my suspension and it was f*****g scary, working on the car at the moment to adjust the geometry then i will concentrate on getting the traction control set up to suite the car.
Old 07-05-2010, 09:22 PM
Rab
Rab's Avatar
You're a brave man! Or insane. I can't tell which
Old 07-05-2010, 09:24 PM
Roosie
500bhp Cosworth in making
Roosie's Avatar
thats is the identical engine spec to mine!!!!! mine will be mapped in summer cant wait.
Old 07-05-2010, 09:27 PM
pauljh
pauljh's Avatar
Hi,
Who is doing the engine build and who is mapping it?
Old 07-05-2010, 09:38 PM
bad boy rs
bad boy rs's Avatar
fuck me thats mental
Old 07-05-2010, 09:53 PM
pauljh
pauljh's Avatar
Steve by the way is steveboyslim on this forum, if you need anything give him a shout, he can sourse most things.
Old 07-05-2010, 10:02 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
You're crazy, I would be having the boost mapped to throttle position to give you a fighting chance of actually keeping the thing in a straight line .
Old 07-05-2010, 10:08 PM
pauljh
pauljh's Avatar
Hi Mike,
I'm hopeing the traction control will deal with any issues,
PS my new suspension.
I just need to learn to drive on track now, all you hard core track day drivers are going to overtake me on the corners!!!
Old 07-05-2010, 10:20 PM
Mike Rainbird
Caraholic
If you do that, the car will be slower than making it driveable, as the TC will be working almost non-stop .
Nice choice, the best people have this suspension .
Old 08-05-2010, 08:35 PM
pauljh
pauljh's Avatar
you may be right Mike, i will get it set up and see how it behaves. I was running 605 bhp and 436 lbft last year at the crank at 2 bar boost, that is similar now to my 1.6 bar boost 550 bhp at the wheels, unuseable in the wet but dry with warm tires and an ambient over about 15 degrees the car put the power down suprisingly well, it was just reassuring knowing that if i over done it i wasnt going up the road side ways at virtually any speed.
This is my old rolling road graph.
Old 08-05-2010, 08:55 PM
AlexF
AlexF's Avatar
wow!
Dont show Porkie this!
Old 08-05-2010, 08:59 PM
mrviper
mrviper's Avatar
how the fuck did that grip on the rollers ?
Old 09-05-2010, 07:56 AM
stevieturbo
C**t
stevieturbo's Avatar
With proper rollers, grip is not an issue until well into 4 figures.
And Torque Developmenst use a RotoTest hub dyno. If Carlsberg did dynos....
Its a fantastic result and a stunning build, and in something as light as that will be truly mental.
BUT.....why is there such a minimal gain from 1.6bar, to 2.2 bar with what is a relatively big compressor ? Or is some aspect nearly maxed out ?
Given the extra heat involved with the extra boost etc is it even worth running such high boost ?
Old 09-05-2010, 10:48 AM
scoooby slayer
awesome power but god it looks peaky in the old graph, looks like youve got a much bigger power band now
Old 09-05-2010, 03:11 PM
pauljh
pauljh's Avatar
I think the GT35R is on its limit, i will probably run at the lower boost setting most of the time, i also fitted an additional silencer whilst on the hub dyno and tested it at full boost, the engine lost 30 wheel hp. I may be forced to use this on track as the car is a bit noisey when on boost at high revs.
I will try to avoid using it as i am concerned with the strain it will put on the rest of the exhaust and more importantly the exhaust manifold hanging off the end of the tail pipe.
Old 12-05-2010, 09:48 AM
AustenW
AustenW's Avatar
WOW missed this thread looks great
Old 12-05-2010, 11:08 AM
XRT_si
XRT_si's Avatar
Brilliant! Any pics of the rad set up?
Old 12-05-2010, 11:16 AM
AustenW
AustenW's Avatar
What sort of 1/4 times and terminals has it done
The proof of the pudding and all that
Old 12-05-2010, 03:20 PM
godrikki
godrikki's Avatar
you my friend are totally insane and are surely going to kill yourself in this top man
Old 12-05-2010, 03:25 PM
Luca
Lukesville
Luca's Avatar
Insane
Old 12-05-2010, 08:03 PM
Rascal Turbo
Rascal Turbo's Avatar
Hi Paul, nice looking car , good to see that the design work and the hours on the phone were a worth while gain for all the effort thats been put in by all involved.....
Quick Reply: H.Engineering, F.Motorsport, Hub Dyno
