cossie boost prob
Old Jan 13, 2005 | 08:55 AM
DAN P's Avatar
DAN P
Default cossie boost prob
right then last night was very cold going up the dulecarraige way booted it and the car peacked at 20 psi and held 14 or 15 should it drop that much ?? spec is greens 3 bar t3 2wd i/c zorst fillter -31
thanx for any help
DAN
Old Jan 13, 2005 | 09:01 AM
AlexD's Avatar
AlexD
Post Miester !
I would say either a weak actuator or slight boost leak somewhere M8....
Al...
Old Jan 13, 2005 | 09:03 AM
B19-TRB's Avatar
B19-TRB
should drop off a bit but not quite that much!
u can try my big gay forge monster actuator if u like!?
Old Jan 13, 2005 | 09:04 AM
DAN P's Avatar
DAN P
you chavs R US one ok m8
DAN
Old Jan 13, 2005 | 09:06 AM
Spiky's Avatar
Spiky
Al...
agreed, mostly with the first point, but worth a check of the hoses
Old Jan 13, 2005 | 09:11 AM
B19-TRB's Avatar
B19-TRB
I would say actuator! but the recpits dan has show its new! but that dont stop it being fooked i know!
just pop up & whip the chavvy actuator off as it worked fine on my car for that week i had it! plus u still gotta take the fookin screen & shit out!
U goin down the castle agian tonight!? was a good laugh last thurs with worg's & that!
Old Jan 13, 2005 | 09:19 AM
DAN P's Avatar
DAN P
yea man could pop down for a few was a good night last time im a bit skint though fooking cossie
DAN
Old Jan 13, 2005 | 09:25 AM
CraigN's Avatar
CraigN
im having this problem too
new actuator time
Old Jan 13, 2005 | 09:26 AM
B19-TRB's Avatar
B19-TRB
shite aint they!
I am no longer a cossie owner!
Old Jan 13, 2005 | 09:27 AM
B19-TRB's Avatar
B19-TRB
I got a lovely spankin new -31 in my bedroom!
Old Jan 13, 2005 | 09:28 AM
boost mad's Avatar
boost mad
what was it setup to run boost wise? and also what does it normaly peak at ( when its not so cold )
CraigN's Avatar
CraigN
-31 pussy boost : just put up a post about my needs will see if anyoen replies
Old Jan 13, 2005 | 09:30 AM
B19-TRB's Avatar
B19-TRB
pmsl @ puusy boost!
i bet u r reccommended to use 1! I was by Karlos!
Old Jan 13, 2005 | 09:58 AM
DAN P's Avatar
DAN P
dont no what norm runs m8 but i no in weston the other day was holding more than 15 psi lol and its been wet every time iv been out lol so not really tested it but i deff no it was holding about 18 psi as craig n has seen it to
DAN
Old Jan 13, 2005 | 10:38 AM
AlexD's Avatar
AlexD
Post Miester !
Just to say at the mo, mine peaks at 24 psi and Hold 22 psi on my current setup
using a -31....
What time you boys off to the castle ?? Might come down later for a beer, wont be
till 10.00pm ish tho..
Al..
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
