fao plumbers/heating engineer peeps, is this a decent quote?
we're needing a new boiler and a few other bits doing, currently got a antique back boiler and a fire that burns white so it's gotta go! details of the work as follows:
drain system
remove all tanks from roof space and airing cupboard
remove hot water cyl in airing cupboard and any unnecessary ancillaries
remove fire place and back boiler from chimney opening and cap off/remove all unnecessary pipework/fitting
supply and fit A rated, 30kw veissmann vitodens 100 condensing combi boiler to cupboard under stairs
run 20 white condense pipe externally to outside drain
run new 22mm gas pipe from meter to new boiler position
run hot and cold pipe work from new boiler to feed all outlets, across 1st floor landing
run 22mm flow and return pipe work from new boiler position and connect existing system on 1st floor
remove existing pipework in hallway and leave legs under floor to feed new radiator position in bathroom at later date
supply and fit new 400x450 rad in 1st floor toilet
supply and fit new 1200x600 double rad in rear bedroom
do all required electrical work
supply and fit wireless room stat
fit trv's supplied by customer
remove and relocate stop tap in kitchen
flush system and add necessary chemicals to protect
remove all waste from site
boiler comes with a 5 yr warranty
quoted £2050.53
it's a family friend quoting the work so is that a good price? seemed a lot at 1st but then theres a fair amount of work there.
would appreciate any input from those in the know or those who has recently had similar work carried out.
many thanks
drain system
quoted £2050.53
many thanks
the scrappage scheme has ended, all vouchers have been allocated, that isnt a bad price either, not a great fan of those boilers though..i would charge about the same
Looks Damn cheap to me, had similar work but quite a few more rads and a worcester boiler and paid 3.5k, also done by someone i know through the trade so i don't think you'll get it done any cheaper!
Yes that's a good price. I've just paid £2500 for a new boiler (system change) without radiators. It's pretty much what your having done but with an old gas boiler not back boiler.
"run 20 white condense pipe externally to outside drain" 20mm? - My mate told me that Worcester Bosch have just told everyone to upgrade their outside drians to 32mm as they were having alot of problems with them freezing up during the cold weather.
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
