jb weld
hi there for a little whiel be advised that jb weld would be able to help with the crack on the exhaust manifold this is a tempory fix does anyone know where this coudl eb brought from today im in essex
needs taking off and re-welding
imho nothing else will do ,unless you replace it with another un-cracked one !!
better off getting repaired by a competent welder , and then look at the cause of the crack ,and remedying that ...
without seeing i cant say but the usual is for people to run big turbo,s with no brace ... either that or just running no brace for the turbo alltogether usually causes them to crack
anyway jb weld or any other cack aint gonna do it im afraid
will just fall off once through the heat cycle once or twice
find a wlder or new manifold your best bet !!
surely you must know someone local with a welder ,even a mig , just remember to preheat like i said in your other post mate
jb weld is good stuff
i have used it on many things in the past
rad leak in house
brass model
leaky water pump stud
and a nitro car head that split in 2
and it still works perfect to this day
and loads more
the stuff is the dogs sets as hard as steel and can be drilled filled ect
sticks like shit to a blanket to any thing
car get at diy shops and car spares shops
and will do the job you need for good probley
paul
rad leak in house
brass model
and loads more
paul
