labour cost to skim a flywheel???
Just checking to see if i am getting quoted a fair deal to have my flywheel skimmed, they reckon £100+vat. Is that excessive? Its a billet flywheel if that makes a difference.
cheers
mark
cheers
mark
Monte 087
that was going through a subaru tuner called greenwood racing developments in surrey and i think the machine shop they use is local to them.
do you think i should offer to get it skimmed myself which might risk the warrentee they offer?
bensham engineering are about 2 minutes from my house so is a good option lol.
Ur best bet is to ring bensham then and ask how much they would charge to skim it, then ring the other place back and ask exactly what their planning on doing/what ur getting for £100 plus vat and give benshams quote (which i doubt will be anywhere near that!!)
They cant really dick u about with the warrenty if their not doing the work themselves anyway, sounds like they've added their cut ontop if their getting somwhere else to machine it
The only thing that would have cost more when i had mine done was if i couldnt get hold of any replacement dowls and they had to machine me some new ones as their obviously small and theres 3, other than that its an easy job!
yeah it does sound high mate thats why i questioned it, its only a skim aswell nothing fancy.
ii'll probably take your advice and ring bensham, i think with the saving i'll make its more then worth my while...sounds like i could save £70!
well tbh if u give the place doing the work a quote from somewhere else they should in theory match the price, or by the sound of it stop taking the piss and charge u what it is actually costing not what their bunging ontop lol.
Are they doing more work aswell as the flywheel or just getting it skimmed for u?!
Supply and fit Helix organic clutch, fluid change aswell mate. I was gonna get the clutch else where but they brought there price down and almost matched it all by 25 quid so i thought i'd go with thats incase they blame the clutch i supplied if anything failed.
Their bumping the extra £25 back in the labour for the skim. Get the flywheel off them and get your local one to do it, tell them you want the same finish as on the outer of the flywheel.
On a job like this my place only charges a straight labour rate, of £20 HR, took 1 1/2 hrs all in, I think it's well cheap, but I have put thousands thier way over the years!!
Man has been doing this stuff for 54 years, got engine dynos road dynos and a mass of machinary, bursting at the seams his building.
