whats the difference in paints?
I was checking ebay their to see how much paint was but its very confusing. I thought their was just cellulose, basecoat and lacquer and 2 pack. I was looking at the 2 pack rosso red but theirs loads of different types like enamel, gloss and acrylic. i take it some of these are for lorries and stuff. Am i right in saying i need acrylic for a car and will any acrylic do?
I heard water base paint was very soft, easy marked or scratched etc. But does water based paint not need to be sprayed in special air cooled booths or something so it dries out?
?????? not sure where you got that as it has lacquer over the top which is no different to what is used on solvent (2pk), yes water based is air dryed, but you can get a hand held blower for about Ł20 from your local paint suppliers, water based is a lot easier to use than solvent, it's alot cleaner (as in not as much over spray dust) and you can put it on alot heavier than solvent, steer clear of acrylic or enamel as they are oil based and a nightmare if you want to paint over the top in the future
Smokin'
Interesting thread
I've steered clear of water based as I've heard such terrible stories from shops that were forced to change to it. They miss 2K even 8 years down the line
I will stick with 2K till I can't get it anymore, and I do the odd cellulose job on earlier stuff for originality
Waterbased if the parts are cleaned properly tends to react less due to not having thinners in it to thin it down!! You dont use normal water thou has to be deionised (some places tell u to use branded stuff but its all essentially just deionised water!!) but its cheap to get hold of.
The only thing with water based is if u spray it in a cold enviroment it'll take ages to flash off unlike solvent, as said its air movement that helps aswell as a bit of heat, and althou u can buy the hand air diffusers u can even just use air from the gun to dry it off!! As said as long as u make sure its dry before lacquering then it doesnt really stay soft, but u have to make sure its 100% dry!!
It can go on heavier but you still have to be careful with it as it'll still run and then takes even longer to dry!!! The idea thou with alot of them is solvent can take 2-3 coats to cover whereas alot of waterbased should only take 1-2 so ur using less, but obvioulsy doesnt always work like that
Price wise thou waterbased is more to but than solvent so doenst work out much cheaper unless u obviously get it in bulk orders!!
rsguy
44
29-09-2015 03:29 PM
SMILER258
28-09-2015 09:04 AM
