4x4 to 2wd help needed
Hi All,
Tryed searching but didnt get much luck!!!
SO...
Iv just got myself a 4x4 sapphire cosworth nearly rolling(back only) but i want the car to be 2wd, if i was to buy a 4x4 front cross member, Bottom Arm, ARB etc would 2wd hubs fit and run on that setup ok and would the engine sit in the right place to then run 2wd setup at the back???
any help welcome James.
SO...
Gary Krishna
All I would do is use the 4x4 front hubs and just seperate and gut the outer C.V. joints and refit them to keep the bearings under compression. I can't see any issue with doing this. This the way I'm doing mine.
If you wanted to make a nicer job of it, you could have the cup section machined off the C.V. Joint for a neater look. Again, this is what I'm doing on mine.
jason_nike
18-08-2019 10:53 AM
rog
04-09-2015 12:10 PM
