what would suit an 8ft tank
virgin only up the A hole
as title states i have an 8 ft fish tank as a counter in my new garage was on about putting cold water fish in tank as minimal needed to keep them pump food etc but what else could i keep in there with minimal costs ie nothing that requires a heater of sorts any suggestions please feel free to add i will add pictures tomorrow or if all else fails it will make a good display cabinet
an what sort of cost would i be looking at for a pump
Ye, You can pick up a few cheap pumps on ebay. the size of this tank you will need a minimum of 2 big pump filters such as ehiem or fluval 404s. Dont put gravel or sand in the tank as this will just collect a lot of waste from the fish and without gravel the pump will easily collect the fish waste. It is not much price differnce in setting up tropical or coldwater. with a tropical all you really need is a few filters and 2 heaters. Heaters can be picked up for about £10-15 each. And with tropical you have much more choice with various fishes.
No really, 2 x 200Watt heaters in there will be fine.
A large tank with piranhas or Oscars look great with nice rockwork and some braches.
As said with a few good filters turning over the water well and with no sand or gravel your water will be kept clean. All you
Have to do after setting up that is to change 20-30% of the water every month ideally with RO water.
That pump is fine. But remeber a pump will not clean your tank you will need a few powerfull filters like fluvals or eheims.
A pump is just really to add devices like air stones. You dont relly need pumps you need filters
If I was you I would stick with the big names in aquarium filtration like Fluval, Eheim and interpet.
I have been using a fluval 404 in my tank for 2 yesrs now and I have never had problems and they don’t block
Like cheaper makes. At the end of the day you are mixing electricity with water so buy the best and never buy
Second hand aquarium electrical products as you don’t know what the previous owner did with them.
2 x powerful filters
2 x powerful heaters
1 x powerfull air pump for air stones etch ( for bubbles )
1 x powerhead for water surface flow (creates oxygen for you fish) flow just above the water surface
Rock work
And your fish.
Rock work
And your fish.
SMILER258
28-09-2015 10:04 AM
