Sand Blasting A Bodyshell
Series One
Brian,
I have panels blasted before came out really well. I've also used sand blasting when i was restoring my Mk1 Mex which came out quite well as well. But to be honest there are better things out there now.
Check out these.
http://www.surfaceprocessing.co.uk/for-cars.html
or this sounds really really good not as agressive as shot blasting.
www.soda-blast.co.uk
http://www.suttonsodablasting.co.uk/home.html
cheeRS
Barney
Check out these.
cheeRS
Barney
Had a 3dr Blasted ,every time i raced that car it was like a sand storm in the cockpit ,literally cup fulls would keep coming out of the seams whatever i did to clean it out !
Brian,
Check out these.
cheeRS
Barney
Check out these.
cheeRS
Barney
I had to have the whole car repainted as the job the 1st body did shop was very poor
There are some fibreglass parts the new paint guy wanted blasting so i thought i would get the alloy engine grill blasted at the same time.
Called Sutton soda blast 5 times and got no answer! Tried a few days and finally got though to him but his attitude on the phone was not good. So i ended up going to Roy at soda blast UK.
I took the 2 fibreglass parts and the alloy grill to him, to cut a long story short he could not blast the fibreglass without damaging them but blasted the alloy engine grill. He said it took him 3 hrs and charged me Ł170 !!!
My point is, soda blasting is easier on the metal work than normal grit blasting but it takes a lot longer to do so is a lot more expensive.
Hope this helps
I have used surface processing to strip 2 doors and an engine grill and they were very good. The engine grill was alloy and they had to strip that separate, it cost me Ł50.00 just for this part.
Hope this helps
Hope this helps
I have spoken to my mate who is going to be doing the welding and pianting and he said about just getting the underside blasted and maybe the inside but thats it, said it will be loads easier to weld after its been blasted as all the metal will be nice and clean
Thanks for all replys
Brian
3doorcozmess
20-09-2015 06:15 PM
jonfoc
11-09-2015 04:46 PM
rog
30
29-08-2015 11:16 AM
