reset p8 memory
Old Mar 19, 2010 | 09:04 AM
Ben M's Avatar
Ben M
Default reset p8 memory
can someone post up how i can reset p8 memory as mate is having probs with his car but as things have been unplugged ignition on with no engine etc want to start here
cheers
Old Mar 19, 2010 | 10:28 AM
ECU Monitor Enthusiast
Unplugging ecu or sensors or battery will not cause problems as when its all plugged back in, the ecu will just carry on as it doesnt use battery backup memory.
There is flash memory on the ecu which doesnt need power but this is only used to store closed loop fuelling learning information.
I dont think performing an ecu reset will help you as I think you have other issues !
How you reset the ecu also depends on the type of chip installed too and may not even be possible.
Although, if all is working correctly, this data will be relearned anyway !
Perhaps you could tell us what the problems you are having are ?
Old Mar 23, 2010 | 08:30 AM
Ben M's Avatar
Ben M
cool, it seems to have fixed itself after just a fuel filter change.
Old Mar 23, 2010 | 09:28 AM
Stu @ M Developments's Avatar
PassionFords Creator
Sorry, in my experience it wont, especially if its had a Pectel board in it.
Old Mar 23, 2010 | 09:32 AM
Which is why I said depending on chip type
Pectel really didnt do a good job in their software in that area !
Kam B
Sep 24, 2015 10:40 AM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
fuzzy
Sep 4, 2015 10:11 PM
