Clutch, 4wd escos,350+ AP 4paddle or alcon 6 paddle???
which would be best?????
i dont care if it's a bit rough on road, as it wont get many road miles
cheers
spiky
cheers
spiky
Originally Posted by B19-TRB
4 paddle!
I asume the less surface area of clutch the better!?
Originally Posted by Spiky
which is gonna last longest???
as neither are cheap and i'd prefer ti have the longer lasting one
i mean do you ride the clutch
i learnt afteer warping my old flywheel the clutch is best used on or off if your on a hill use the handbrake lol
i never ride the clutch in me cossie now my fiesta gets all the abuse, ive allready had a new gearbox and clutch in that
Caraholic
Be aware that any of the paddle clutches will put a strain on the standard ratchet mechanism and you would be well advised to change it for either the GGR manual set up (at the very least) or hydraulic it. This will then remove the clutch dragging / pedal sticking to the floor problems when giving it large.
mike my pedal has started to creak
liek a wodden trap door squeaks for brittain every time i put the clutch down
what is the setup you mentioned above (not the mega Ł hydraulic setup)
i was just gonna replace my clutch cable again
Martoon does it! thye prices r on his site!
the GGR thingsy is Ł150 on their website!
& it says Ł25.74 for a GGR Clutch Cable! any idea if this is any better than standard!?
