HELP how do you test a cps (cranp postions sensor)
Old Mar 12, 2010 | 06:32 PM
steves24V's's Avatar
steves24V's
Default HELP how do you test a cps (cranp postions sensor)
Hi can some kind person please tell me how to test a crank position sensor with a multi meter its a 3 wire vauxhall one.
cheers steve.
Old Mar 12, 2010 | 06:37 PM
ECU Monitor Enthusiast
You can use a resistance meter to measure the resistance of the sensor as it is just a coil of wire.
Expect a reading between 800 and 1800 ohms.
You can then switch the meter to AC voltage and crank the engine.
You should see a voltage of at least 20 volts when disconnected from the ecu.
The only reliable way of checking its operation is when it is connected to the ecu and using an oscilloscope to view the wave form.
Old Mar 12, 2010 | 06:39 PM
steves24V's
cheers but any idea which two out of the 3 wires i need to stick the meter on
Old Mar 12, 2010 | 06:41 PM
Sorry, I assumed you were talking about a cossie sensor
What car is this from ?
EDIT :: I am fooking blind
I dont know the vauxhall ones ... Sorry !!!
Old Mar 12, 2010 | 06:45 PM
steves24V's
Should have gone to spec savers !!! lol
cheers anyway its a mk 4 astra non start.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
