Yb rev limiting factor?
Where is the weak link in Making a yb rev? With stronger rods, pistons etc, what stops one being revved to say 9k? Would solid lifters be good enough, or would you need to go one piece valves as well?
I am no expert on the mechanical side but I would guess solid lifters are the first thing and a blue printed balance of the whole bottom.
The YB Piston dimensions were designed for high revving IIRC !!
However, as far as engine managment goes, I wouldnt run the L8 or P8 above 8500 rpm as they are not fast processing and could miss crank pulses.
You may need bigger injectors to reduce the duty/rpm ratio as there will be less time for them to pulse open between cylinder firing events.
Coil pack ignition or a high energy coil may be needed as again, the coil charge times will be reduced at high rpm and could reduce spark strength.
Mark
std YB rods are VERY strong as I understand it. They are just heavy... and at 9k its alot of weight to be slinging around!
but as Mark said.... why you wanna rev that high mate?
P.S 3.6 is a much better engine size to start with
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Also Will, if you want to go for silly high revs, you are also going to need to address other areas such as oil pumps (you might want to consider dry sumping for those sort of revs), cambelt tensioners, cambelt idlers, alternators etc.
T4/GT30 stuff with a rev limit of 8k is plenty fun enough
just to throw one in the mix
the engine i just dropped out the old mans car
rev limit of 9200 rpm, this was only due being needed for the gearing top end due to the ffd ratios
peak at 8k,
7.5k 608bhp
8k 613bhp
8.5k 604bhp
and didnt take a reccording at 9k but iirc it had dropped a little but still rather good for a yb
the torque max figure was 456lbft on a straight 2.0, so not bad considering theyre very top endy cams
that engine was std/std crank, high pressure oil pump no dry sump , standard tensioners, idlers, grp a alternator, and no problem for 2years of track abuse,
peak at 8k,
7.5k 608bhp
8k 613bhp
8.5k 604bhp
Was looking at it simply to extend the powerband.
Porkie, It might still be an option, but putting 35k into a car at the moment is a massive decision as I might need the cash in a year or so, as I might be leaving the RAF..
peak at 8k,
7.5k 608bhp
8k 613bhp
8.5k 604bhp
peak at 8k,
7.5k 608bhp
8k 613bhp
8.5k 604bhp
when did you see full boost???
cheers danny
surely its alot quicker and easier to sell one 911 Turbo.... than a truck load of cossie bits, than may or may not be working at the time!
Not a massive Evo fan, and you are still on a 2.0 highly strung turbo engine.
I think for the time being I have to sort the Cossies, then see what's happening in a year or so!
wowk
Mar 30, 2021 07:49 PM
SMILER258
Sep 28, 2015 09:04 AM
Vacuman
Sep 22, 2015 12:09 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
