Mapping complete 12/3/10 - 400+BHP @ 26.8psi!!!!!!
popped up to see the nova after work managed to catch dave hard at work just before he called it a day!
nova is currently 315bhp @ 12-13psi equates to around 265-270@ wheels
hopefully dave will finish up tomorrow and hopefully get boost up to 25ish
well had a phone call today to say the nova was boosting to 25psi and was making in excess of 350bhp ATW
dave's rollers only read up to 350 ATW so the rest of the graph flat lines, but we think its around 400-420 @ flywheel (360-380 @ wheels) as we have reached the limit of the t34 0.63 hybrid turbo and they are known to flow a max 390-420bhp
in a car that weighs sub 800kg will be one fast little car
i am collecting tomorrow with one tired operator and tyres that are almost bald due to the wheels spinning, but im happy its stayed together and everything has worked well
gary
gary
tubular manifold
hybrid t34 0.63 turbo
3" exhaust from turbo back
ported and polished cylinder head with +1mm oversized valves
kent valve springs
c20xe inlet and exhaust cams
kent pulleys
1mm cometic mls head gasket
omega 87mm pistons
total seal rings
farndon h section steel rods
billet oil pump
john toovey baffled sump
sbd nylon relief valve
sbd uprated cambelt idler rollers
billet lightened flywheel
helix 4 paddle clutch
750cc injectors
ah fabrications chargecooler system
emerald k3 engine management
regardless to what you set the boost control solenoid too
25psi low down is at 40% duty cycle
higher up we put 100% duty cycle in and it made no difference
so my thoughts are that the turbo has reached its limit and cannot supplied the amount of air required higher up to meet 25psi
but either it will be plenty fast in a sub 800kg car
a good mate of mine has just got his Corsa turbo runnin nice after 2 rebuilds and trying to run it in on 26psi!
made 440summit bhp with a nice 100shot of nos when needed
looks aint to everyones taste... but it F***ING shifts!
there was another yellow turbo around 400bhp mark (my mate gareth owns welsh coast customs , powerflow dealer) but its now been broken for bits and sold back last year!
the nova is now safely home in the garage to say i am over the moon with the mapping is an understatement
it idles perfectly from cold, on 750cc injectors and 3 bar fuel pressure
havent driven it properly yet only off and on to the trailor and down the short run up the street and into the garage!
i have a graph but it only reads 278bhp @ the wheels at 4250rpm it flat lines to 6500 before dropping off
torque flat lines also at 330 ft @ the wheels at 4400rom
the rate its increasing the mapper worked out that its around 350-360 @ wheels
which equates to 400-410 at flywheel
its holding 26.8psi
oil change tomorrow i think, a final nut and bolt check fit bumper and get it mot'd early next week
big up to dave young at mech motorsport he has spent in excess of 20 hours on it, i am very happy finally
ebngine did 500 miles on the rollers over the last week with out a single issue
its holding 26.8psi
absolute awesome results there always loved novas (used to own a highly tuned sr ) but with this engine in and the right suspension/brake set up they are a real weapon i fount a pic of the green 4wd nova turbo the other day on my pc that was around 400bhp as well
yes the rollers were maxed out, but the rate it was increasing at 3750-4000-4250 was 26bhp per 250 rpm
his rollers are fine usually for what he uses them for mostly n/a engine which never see 270-300 ATW on very few occasions he gets some powerful and it just flat lines!
by the looks of the graph and having to estimate as it flat lines at 4250 @ 278 and drops below 278 at 6500rpm
350 at wheels calculated on the graph using the current rate of acceleration is around 5200ish rpm
Fantastic results though from your car,hopefully il see it around one day and have a nose around it.Is there any nova meets around south wales?
it will be on track a but this year i wont drive it on the road much, may if i find it reliable take it to the ring in may or june!!
here is the graph
this is wheel horse power
here is the graph
