Showers and Combi Boilers......
Old 09-01-2005 | 02:27 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Showers and Combi Boilers......
So, whats the best type of shower to have with a Combi Boiler??
We have seen lots of designs we like, but know that some aren't compatible with Combi's, we just dont know which.
Old 09-01-2005 | 03:46 PM
TIFF's Avatar
TIFF
Chasing Radders
Combi boilers can run a normal "Theremostatic" shower if you want it to, ie Hot and cold water feeds to it. BUT as you may be aware Combi boilers dont have the best hot water flow rate
You could have it Pumped which would get rid of the low pressure problem but at a price.
The other option is a Mains feed electric shower, which if you buy a top brand one you will be more than happy with as the power of them is painful at times
Good brands for both showers are Mira and triton
HTH
Old 09-01-2005 | 04:14 PM
Lee Reynolds's Avatar
Lee Reynolds
As tiff says Christian, we run our shower off a 100,000 btu boiler and its a good hot powerfull shower....till our lass turns the tap on downstairs then it slows and runs cool. Should have had it pumped but as we hardly use the shower i didnt bother IMO go electric
Old 09-01-2005 | 04:20 PM
Jamz's Avatar
Jamz
If my missus runs a tap downstairs while I'm showering with our electric shower burns the fuck out of me Not something you want while washing your nuts
Old 09-01-2005 | 04:29 PM
M Brian's Avatar
M Brian
only problem with the electric type showers is the level that your tank is if youre on non combi.
i dont get the best pressure out of mine cos it doesnt have enough height.
how much are combi boilers and fitting? as id like one in my house as ive only got a little old baxi normal one and would be good to get rid of the water tank and things.
Old 09-01-2005 | 04:32 PM
Lee Reynolds
M brian your electric shower isnt run from the tank, its run from the cold feed which is pressurised locally.
Lee Reynolds
oh and a lot of firms advertise combi and 6 rads for around 1500-2000 depending on type
Old 09-01-2005 | 04:34 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
our worcster 28cdi is more than ample for our thermostatic mixer
as tiff will tell u the problem is with combi boilers its not the heating btu but its the dwh (domestic hot water) flow and the cheaper boiler the wanker the dwh flow is if anyone local needs a boiler i will be happy to price one up @ less than trade as i work @ plumb centre
Old 09-01-2005 | 04:36 PM
Rs Gus's Avatar
Rs Gus
you should pay Ł1k apx for combi a boiler if u ask me and u will get a decent one
Old 09-01-2005 | 04:46 PM
TIFF's Avatar
TIFF
Chasing Radders
Gus
I didnt know you worked for Plumb Centre
Old 09-01-2005 | 04:47 PM
Jamz's Avatar
Jamz
Do you have to be a trader on here to sell boilers
Old 09-01-2005 | 04:49 PM
Jamz's Avatar
Jamz
http://www.passionboiler.com/
Old 09-01-2005 | 04:51 PM
M Brian's Avatar
M Brian
@jamz
cheers lee.
ive obviously missunderstood how it works as im sure when we installed my dads it lsted the low pressure as being due to not enough drop
Kev.H's Avatar
Kev.H
i gotta combi and my shower is just a normal tap swivell shower one no power just gravity but somehow they got it coming out like a fecking pressure washer
Old 09-01-2005 | 05:01 PM
TIFF's Avatar
TIFF
Chasing Radders
Kev
All depends on the "head" of water you have.
That is from the top of the shower head when it is at its highest position, to the bottom of the water tank in the roof that feeds it.
Melv
The higher the drop, the more pressure if you are using a gravity system
steviep's Avatar
steviep
Default Re: Showers and Combi Boilers......
You'll get the best performance from a mixer valve, electric showers aren't worth a wank. As Tiff said, Mira are good but you end up paying over the odds for the name. At work we deal with a company called A. J Gummers and all of their shower valves eclipse Mira's spec on every level for a lot less money, you also get a longer and more comprehensive guarantee.
We've got a fully thermostatic valve in the january sales for Ł65
Old 09-01-2005 | 05:16 PM
Dunccoss's Avatar
Dunccoss
best shower for combi boilers are pressure balanceing ones like the mira 415 that will work best, most combi boilers will only run one hot tap / outlet at a time but with this shower if someone opens a tap the temp will stay the same but the flow and pressure will reduce untill the other tap is closed. You will not get any electric shower evern close to the temp and flow rate of these.
Old 09-01-2005 | 05:41 PM
Christian and Beccy
#1 in Spelling Club
Thanks everyone for your help.
What we are planning to do, is fit a Quadrant Enclosure (Probably 900mm or bigger) in the corner. We then want a *BLING* Shower with as little on show as possible. So probably a Controller and a Shower Head mounted on the wall.
We saw some 'Hudson Reed' Showers today that look just what we want. Just need to check that they are good/suitable. This isnt necessarily the exact one we want, but something like it.
http://uk.hudsonreed.com/loadbuy5b/1...A/sh/sh10.html
Old 09-01-2005 | 05:43 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
use a 'mira form' it works superb with a combi
Old 09-01-2005 | 05:47 PM
TIFF's Avatar
TIFF
Chasing Radders
Christian
That shower would have to be pumped mate as it uses 3/4" feeds.
What combi have you got and what flow rate the DHW (domestic hot water)???
Old 09-01-2005 | 05:53 PM
Christian and Beccy
#1 in Spelling Club
I will have to have a look on the Boiler. It is a 'Vaillant' one, but thats about all I know.
How can I find the DHW flow?
We will probably change the Boiler for a more powerful one if we have to.
Old 09-01-2005 | 06:07 PM
TIFF's Avatar
TIFF
Chasing Radders
I think that would be an idea mate
Usally get the DHW flow rate in the user handbook
Old 09-01-2005 | 08:08 PM
Dunccoss's Avatar
Dunccoss
if it a vaillant the flow rate whould be 9.5 lts per minute for the 824 / or 10.5 for the 828 these are the two most popular, you can not put a pump on a combi shower, does not matter what size the conections are on the shower, you will need 15mm hot and cold supplies then just increase at the shower valve
Old 09-01-2005 | 08:19 PM
Lee Reynolds
This is what we have. Only thing i regret as said is not pumping. ut we hardly use it so fook it.
Old 09-01-2005 | 08:32 PM
M Brian's Avatar
M Brian
fffffooooooooooook i so shoulda gone two colour on my bathroom that looks ace lee!!
this is mine 30 seconds ago
ive gotta hide the shower feed yet though!! I hate houses lol
Old 09-01-2005 | 08:38 PM
Rs Gus's Avatar
Rs Gus
try here lads for shower stuff my mate owns it hell do u a good deal
www.wilsondobson.co.uk ask for mark tell him gus sent ya
Old 09-01-2005 | 08:40 PM
Lee Reynolds
Looking nice that Melv. You doing it yourself yeah???
Old 09-01-2005 | 08:43 PM
TIFF's Avatar
TIFF
Chasing Radders
Check out Melvs Toffee hammer
DIY'ers eh
Old 09-01-2005 | 08:48 PM
M Brian's Avatar
M Brian
lol@tiff whats up with my hammer??
i get told off by my mates for using a ball peen one for wood work so had to steal that one lol
yeah lee im having a go at doing it myself but im taking ages as cant be bothered!! ive not had a bathroom since august 15th so no rush is there
it was a separate toilet and bathroom but now its just one room lol had to build a studded wall and stuff which is what took ages too.
Lee Reynolds
DIY'ers eh
nice shiney level too
Heres rest o mine Melv. Not big but made use of space. Plenty of room to get dry etc.
Old 09-01-2005 | 08:50 PM
Lee Reynolds
youll get there m8. Our house took a year and still aint done ive gone lazy(plus doing car lol)
TIFF's Avatar
TIFF
Chasing Radders
@ The air freshener on the bog
Old 09-01-2005 | 08:53 PM
Lee Reynolds
lol had to get that out the cupboard tiff had a balti last night
Old 09-01-2005 | 08:56 PM
TIFF's Avatar
TIFF
Chasing Radders
That would explain the shower attachment on the taps then
Old 09-01-2005 | 08:57 PM
M Brian's Avatar
M Brian
oh get it now!! its cos they aint been used!! lol
well ive had to buy all my own tools and stuff well actually the hammer and level arent mine!! half inched them from a mate lol
you observant fookers - picking up on the air freshner aswell you ever tried that spot the ball competetion thing?? youd be loaded!!
Old 09-01-2005 | 08:59 PM
Lee Reynolds
lol!!! Aye shower head instead of a bidet!!!!
Nah got that shower head on the bath too so our lass can rinse her bloody hair.....i just rinse mine in the bath water WOMEN
Old 09-01-2005 | 11:00 PM
Christian and Beccy
#1 in Spelling Club
http://uk.hudsonreed.com/loadbuy5b/1...7/sh/sh16.html
So, knowing that I have a Combi Boiler (OK, so I aren't entirely sure of its spec at the moment), how would the system in the link above work? It is described as a Complete Shower Pack, but there isnt alot of info.
All I can see in the pic is a Shower Head and Control Panel. Does it have a Hot and Cold Feed? Is there some kind of Pump? Can a system like this run with some kind of Independant heater/pump thing in the loft?
Old 10-01-2005 | 07:56 AM
Dunccoss's Avatar
Dunccoss
yes that would be fine with your boiler, the only thing they ask for is a pressure reducing valve if your mains is over 5 bar. the shower is just a valve and head, no pump ect as i said befor you can not pump with a combi
Old 18-01-2005 | 07:19 PM
Christian and Beccy
#1 in Spelling Club
Thanks Steviep for the brochures.
Now we are looking at boilers, what is a good rate of DHW, adequate to provide an excellent performing Shower?? 16 Litres per min?
Old 18-01-2005 | 09:37 PM
Christian and Beccy
#1 in Spelling Club
bttt
