MOT failure question...
Just had my shonky MOT fail its MOT two things i agree with but, he also failed it on O/S rear brake disc pitted. He calms its on the inside of the disc, now i only had new discs and pads on the rear last year! Seems strange to me, would you expect this to happen within a year?
I have ordered new set to go on the back, but going to ask a different garage to carry out the work and tell them to double check the disc before fitting to see if its true.
wouldnt have expected that. can they even see the inside face properly with the back plate on??
my focus past last year with shot rears. when i changed them this year i found massive uneven wear but it passed cos the front face was fine and they couldnt see the back due to the plate being in the way.
there prob being stupidly picky and if there is any it will prob wear off fairly soon.
if the pad didn't sit right on the disk (which can happen) then it may have caused uneven wear and corrosion to the disk, I saw it on my wifes fiesta years ago ,from the outside the disk looked fine, but on the inside only about 20% of the disk was actually touching the pad!
steve
steve
Hmmm will have to check, but it seems to be very picky. Maybe a common problem with 306 judging by what Kosman said.
Freaking thing has had loads spent on it recently when i im looking for a new car atm
£30 for new rear discs and pads, urgh. Will have to get them fitted along with the new front suspenion arms.
ive never failed a car on discs.(mainy cos' ive never seen a cracked 1)ive failed loads for brake performance related issues.
i remember on the mot course the instructor shows the class a really knackered old disc and i mean really knackered and asked everyone what they should do,everyone said fail,instructor replied 'pass and advise,the brake performance test will show whether it is working effciently enough.
what utter load of toss, if there is corrosion on the discs its basicly pitting of the discs, read your fail criteria on the computer and there is 2 failures for discs 1 for pitting and 1 for scoring amongst others , ive been testing for donkeys years now and allways watch posts on here about testers failing cars that according to the p/f users should have passed , ill bet there is only a handfull of mechanics on here and only half of those are testers, yet there is allways loads of replys talking shit,
if you were not happy you should have got an appeal form and sent of your 55 quid and waited and seen to see what happens!
A while back one of our testers failed a car for pitted discs, the guy appealed.
The ministry sent a guy out to retest the car and check the discs - he checked and passed the car - telling our tester that he couldnt fail the car on pitted discs if it passed the brake efficiency test, should be pass/advise .
Now thats from the ministry itself.
Mart.
competant bodger
as for rears being corroded cus the pad aint touching them properly. again it is a fail regardless of performance same with scorelines as well
im glad your not testing my cars
and before you ask yes i am a tester of class 4,5 and 7
Totally agree fella. Im also a tester and always get people moaning about failed item. Fair enough some testers are a little fail crazy but i always incourage the owner of the vehicle to ask questions if unsure.
