Whats happend here?! (cossie front shaft pic)
Just been bleeding the brakes on the front of the cos, i knew it needed a CV boot, but then i noticed this, WTF has happend here?
Has it just seperated, can it be put back together, or is it fucked?
Mounts are good, but its in bits at the moment, it wasn't like that when i took it apart.
I have had track rod end and the bottom arm off it, and been pulling it about sorting the brakes, so its that thats done it i'd imagine, i'll wait untill i get my new springs and then sort it, i hope!
Good call paul16V
Make sure the bearings on each leg don't slide off or you'll never get the feckers back together!
I think this part is actually used on a mini metro or similar shopping trolley!
Resident Wrestling Legend
you can see that he's taking the inner tca bolt out which explains why it's fallen out
enigne mounts would stop it happening on the road when you launch from full lock in some cases
if the tripod bearing falls off, you are fucked as you'll need to find a complete useable shaft from somewhere to get a replacement
it will simply push bcack in again
it's going to need the outer part of the cv to come off though to change the gaitoer, easiest way, just a simpl circlip to pop out, much easier than removing the tripod joint at the other end and potentially running into problems
track.focus'd
12-08-2015 05:53 PM
