difference between 4x4 and 2wd saffs
this may seem a bit dim to you guys but whats the difference between 2wd and the 4x4s engine wise.
im just about to get a 4x4 saff and its got the ar42 turbo on, ive got one of them on my erst (which ill soon be trading in ), which i belive to be standed.
im just a little confused on the differences are the 2 interchangable inlet and outlet wise, any help would be great.
sapphire cosworth 4wd
theres quite a bit of difference mate,you can use the 2wd manifold on a 4wd,its got loads of different mods on it.mines got a t3 on at the mo running nearlly 300bhp,im gona get a t34,green,3 bar map sensor and 3.1 accuator,should be good for a few more bhp i rekon..the possibilitys are endless,used to go skeggy a lot im from sheffield originaly..im over next week and trying to get a few ford owners to meet up at the dome in doncaster on saturday 6th march at 1pm if your up for it mate??
yes you can, but the 2wd head has a bit to support the turbo cast into it (as the turbo sticks out further on a 2wd) the 4x4 doesn't so you will also need a turbo hanger/support/damper whatever you want to call it, lol
saying that unless you are going for mega power there is not much point swapping exhaust manifolds as the standard ones are pretty good.
also the flange on 2wd and 4x4's are the same
hasent got a dump valve neither it backs up boost and chatters reeeeel loud, in my experience with other turboed engines (c20let) which i no inside out, its not good, normally have a recirc valve at least.
the 4x4 is only 2k s0 wasent expecting miricles that why all the qs.
may have to get some pics up on a new thread.
there seems to be a erst amal valve bolted to the top of intercooler not piped to anything nor any wires.
1st 2nd 3rd seems ok 4th at 100mph fuel cut, pops and bangs flames the lot. matey is claiming 330bhp. i had a standared sti classic impreza 280bhp, its not a patch on that. dont get me wrong its the tits and its a cossy.
will have to have another look and see if i can find the plug for that amal valve and pipe it in. the thing is if i start messing with it before i do the deal (my 90spec erst and 500notes) he might not wanna sell it and he got his car sorted for nothing. do i do the deal on a wimm.
acuator could be pre set to say 8psi and it would open at that pressure.
engine does sound nice.
FlashRS
13
31-08-2015 06:02 PM
mrmann
20-08-2015 11:24 PM
