MSD Closed loop problem, help!
Old Feb 23, 2010 | 10:52 AM
JamesH's Avatar
JamesH
Default MSD Closed loop problem, help!
Hi guys,
I'm wondering if anyone has experienced a similar issue?
Done the wasted spark/closed loop conversion
The car will not go into closed loop at idle, has anyone else had this?
I'm running an independant bosch closed loop lambda sensor (not an output from a wideband)
The TPS is set correctly (0.25° at closed throttle via IAW monitor)
The base idle is set correctly (900-1000rpm with ISCV unplugged, coolant temp of 88°C)
The CO screw has been reset and adjusted but makes small difference
It idles at about 12.8:1 AFR. When I put the lights on, and the fans cut in, it leans off to about 14ish, but I'm going to do this, then unplug the lambda sensor, to see if it IS in closed loop at this state or not
The closed loop works everywhere, when driving, that it is supposed to, from what I've seen so far
The only thing I can think of, is that maybe the fueling in the map, is over 40% out at idle, and the closed loop can't correct it enough
Any ideas are more than welcome
Old Feb 23, 2010 | 11:11 AM
stu21t's Avatar
stu21t
I think the tps needs to be set at -0.30 this is what I was told to set mine at for closed throttle, also the idle should be 850-900 with no iscv when hot, if it goes over 1000rpm it comes out of the idle stratergy.
The co screw should be between -25/+25%
if it's all at these settings and it's still not working then either the map is too rich at idle, the cam timing isn't set to the recomended figures, or you have an inlet leak.
If your 100% happy with everything else then Msd will do a new chip with less fuel on idle for you.
Old Feb 23, 2010 | 11:22 AM
JamesH's Avatar
JamesH
I saw a htread last week where James @MSD said he sets the throttle to 0.2° when closed, unless I read it wrong
Idle was 900-950rpm with ISCV unplugged
Tried everything with the CO screw
Cam timing is all spot on, was before and its never been changed
I'm open to any suggestions as I'd love to get it working properly!
Old Feb 23, 2010 | 11:47 AM
stu21t's Avatar
stu21t
https://passionford.com/forum/genera...o-at-idle.html
in there James says tps being set at 0.07 is ok but you can go down to -0.30 if you have a high co, as long as it goes over 80% flat out.
I'd at least try it, also do a pressure test of the inlet system, ud be surprised at what leaks you may find.
Old Feb 23, 2010 | 11:48 AM
ECU Monitor Enthusiast
James,
Does the car control the idle properly with the ISCV ??
To test this,
Put your foot on the brake in first gear and without touching the throttle, raise the clutch very very slowly to the biting point.
You should feel the engine apply more load to maintain the idle speed.
If that works ok, allow the car to idle once up to temperature and unplug the TPS and observe the idle CO for a few minutes.
If all seems ok, unplug 1 injector while running (anyone) for about 20 seconds then plug it back in and observe the CO over a period of about 2 minutes and see if it corrects.
(We are applying a disturbance in order to get the closed loop to work hard)
Otherwise, if all looks ok, your fuel pressure may be a bit high or you have a vacuum hose to regulator leak possibly.
The lambda sensor may be faulty but can only be tested with an osciloscope properly.
Old Feb 23, 2010 | 12:03 PM
boost mad's Avatar
boost mad
when the TPS was set below 0.07% it took 5-6seconds for the car to fire and start.
Unfortunatly my IAW doesnt work when the car is running
Old Feb 23, 2010 | 12:09 PM
JamesH's Avatar
JamesH
Stu,
Says he here aims for .20 closed and over 80 at WOT. Mine is 0.25 closed and 82.2 WOT
https://passionford.com/forum/techni...cv-issues.html
Cheers Simon, will try all that!
Old Feb 23, 2010 | 12:10 PM
stu21t's Avatar
stu21t
My car takes a while to start, never thought the tps would have anything to do with it. Might b worth looking into.
Old Feb 23, 2010 | 12:14 PM
JamesH's Avatar
JamesH
Yep, as Alex says, it took a good 5-6s of cranking to start, but was slightly better when we set the TPS to 0.2
Old Feb 23, 2010 | 12:18 PM
stu21t's Avatar
stu21t
Best thing to do is get it working as best as you/I can then get it given the once over by a real pro.
Old Feb 23, 2010 | 12:26 PM
JamesH's Avatar
JamesH
I don't really fancy a trip to Blackpool to be honest. And we have all the equipment (IAW if it works with a new lead), so should be able to do all MSD can with their help
Old Feb 23, 2010 | 12:34 PM
stu21t's Avatar
stu21t
Yea me to lol and I'm in Croydon so not far from u either. I'm gettin mine setup at Reyland, takin my iaw with me to.
There's only so much you can do with tools and settings that 'should' work the rest is down to experience and knowing what you can get away with.
Old Feb 23, 2010 | 12:36 PM
stu21t's Avatar
stu21t
Old Feb 23, 2010 | 12:41 PM
JamesH's Avatar
JamesH
I didn't realise you were so close mate!
Hopefully its an easy fix for both of us
Old Feb 23, 2010 | 01:38 PM
stu21t's Avatar
stu21t
Yea not too far, we go gokartin in Crawley quite a bit, and my birds mum and dad live in forest row so I'm round ur neck of the woods quite often, never in the 5 tho lol
yea hopefully it's an easy fix, mines workin fine but doesn't means it's at it's best lol
Old Feb 24, 2010 | 08:29 AM
JamesH's Avatar
JamesH
Yeah the crawley go karting is meant to be quite good, not been yet myself though!
for any more ideas
Old Feb 24, 2010 | 09:54 AM
brad's Avatar
brad
You phone'd stu or james yet m8 ? surely one of them would be happy to help you out ?
Old Feb 24, 2010 | 10:23 AM
bigal1978's Avatar
bigal1978
that would be to easy
Old Feb 24, 2010 | 10:31 AM
stu21t's Avatar
stu21t
Lol if he's anything like me he won't wanna bother busy people with a silly little question, plus it's nice to have it written down somewhere that you can always go back to.
Old Feb 24, 2010 | 10:47 AM
JamesH's Avatar
JamesH
Yes, I am in email contact with Stu, which I find easier, as I tend to forget to mention things over the phone. I've sent Stu 3 datalogs from last night, which he requested, so hopefully that will show something up
Exactly Stu, plus the fact, people tend to remember things that happen to their own car, (if they've had similar problems) very well! AND it may help others in the future once I get this sorted
Old Feb 24, 2010 | 11:19 AM
onslack's Avatar
onslack
the new go karting place is really good
good luck in getting it sorted, hopefully the info you gathered last night will highlight an issue
Old Feb 24, 2010 | 11:21 AM
JamesH's Avatar
JamesH
Will be great if it does Terry!
Old Feb 24, 2010 | 11:25 AM
stu21t's Avatar
stu21t
The kartin place is the nuts, only 6 months old, is wicked when they open all 3 floors up.
Were goin next Friday.
Old Feb 25, 2010 | 03:49 PM
boost mad's Avatar
boost mad
you got any further James ?
Old Feb 25, 2010 | 07:10 PM
Toe Knee's Avatar
Toe Knee
so close yet so far lol, u still got that soft top 5 stu?!
James, if u want to try it all in my car ur welcome too!!! but u wont get it back after sorry
Old Feb 25, 2010 | 08:36 PM
stu21t's Avatar
stu21t
yes m8, in my back garden awaiting some love.
Old Feb 26, 2010 | 12:13 PM
JamesH's Avatar
JamesH
Stu that must be fookin NUTS!
I'm hopefully being sent a chip today with less fuel at idle, as I think it is in closed loop, just can't correct it enough...it goes to 10:1 with lambda unplugged
Tony, nice try
Old Feb 26, 2010 | 12:34 PM
stu21t's Avatar
stu21t
Msd are good like that, did the same for me.
Yes m8 it's wicked fun, 200 bhp/trq, roof down system up cruising car.
I'm a bit old for it now tho and get embarressed by the attention it gets, lol
I'm gunna restore it back to it's former glory by putting a STD bodykit back on it.
I might even put it back on the road for summer this year.
JK12
33
Apr 26, 2021 12:09 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
pabloXR
Sep 21, 2015 12:42 PM
tib2220
Sep 14, 2015 12:33 PM
RSmark84
Sep 13, 2015 01:29 PM
