Compression ratio again
Old Feb 20, 2010 | 09:15 PM
mattman1234's Avatar
mattman1234
Default Compression ratio again
can you tell the compression ratio by filling up the bore through the spark plug hole when the engine is at tdc ?
Old Feb 20, 2010 | 09:24 PM
mattman1234
i know this sounds stupid,but i had my pistons machined,lower compression and valve cutouts,and i can't remember what it was,think it was 7.5.1.
The plan was to have it live mapped by the chap who had all the engine parts machined for me,as he speced my engine for about 380-400 bhp,but i now want an msd chip.They said was going to run light blues on t34.48
Old Feb 21, 2010 | 02:12 PM
LHD220Turbo's Avatar
LHD220Turbo
what engine are you talking about? YB?
if so; what is the bore measurement
Old Feb 21, 2010 | 06:19 PM
mattman1234
yep,its a yb,1st oversize
Old Feb 21, 2010 | 06:22 PM
J1mbo's Avatar
J1mbo
B1mbo
who machined your pistons ?
mattman1234
JTECH James's Avatar
JTECH James
Passion for Fords!
dont think we have many light blues files for off the shelf application, i would go 55s, as for CR, if its unknown ideaaly live map it.
Old Feb 21, 2010 | 06:25 PM
mattman1234
I,m not sure who machined them,i just gave a box of bits to the chaps,and had it all back done.
Old Feb 21, 2010 | 06:27 PM
mattman1234
Old Feb 21, 2010 | 06:28 PM
mattman1234
I'm certain it was 7.5.1,i might give them a ring,hopefully they won't get the arse.
What sort of power would an msd chip be.
Old Feb 21, 2010 | 06:30 PM
JTECH James
Passion for Fords!
on a t34 48, flat out 360-370
Old Feb 21, 2010 | 06:32 PM
J1mbo's Avatar
J1mbo
B1mbo
and the rest james, we have done plenty on the dyno above that
im sure you guys can get a bit more
Old Feb 21, 2010 | 06:33 PM
JTECH James
Passion for Fords!
not off the shelf, we never over quote figures, if they make more so be it
i pushed my .48 very very hard, and saw around 380bhp/420lb/ft, they just run out of puff too early for much more than that
Old Feb 21, 2010 | 06:34 PM
mattman1234
does lowering the compression make a difference on the power output from standard,i was told it would stop detonation
Old Feb 21, 2010 | 06:35 PM
J1mbo's Avatar
J1mbo
B1mbo
not off the shelf
ok fair enough, a recent engine of ours did 380 something cant remember exactly on an off shelf chip so thought you were being a bit conservative there mate better than being over though
Old Feb 21, 2010 | 06:38 PM
mattman1234
going back to msd,does it make a difference to the programming if it were 7.5.1 or standard 8.1
JTECH James
Passion for Fords!
we could easily do your turbocharger chioce on std comp
Old Feb 21, 2010 | 06:39 PM
JTECH James
Passion for Fords!
yep, the pistons in your pic are certainly not std CR
Old Feb 21, 2010 | 06:41 PM
JTECH James
Passion for Fords!
exactly mate, i love the .48, ace road spec mine used to get a bit hot at 36psi though
Old Feb 21, 2010 | 06:42 PM
mattman1234
The problem is,where i want to take it to be live mapped,they do it on the road,when its dry they are to busy,they quoted me 380bhp,but if msd can match that with a next day delivery and a set of siemens,then its got to be msd !
Old Feb 21, 2010 | 06:43 PM
J1mbo's Avatar
J1mbo
B1mbo
i bet they didnt last long lol
this is what i want im my saff first, makes such a nice road engine !
Old Feb 21, 2010 | 06:45 PM
JTECH James
Passion for Fords!
did 75k miles on one turbo belive it or not! never gave any trouble!
apart from killing 3 gearboxes in a year
Old Feb 21, 2010 | 06:46 PM
J1mbo's Avatar
J1mbo
B1mbo
lucky with that one ! some last a couple of months
yours was 4x4 was it ?
Old Feb 21, 2010 | 06:47 PM
LHD220Turbo
who were you going to take it too; quite a few capable people round kent way
JTECH James
Passion for Fords!
yeah, i had to get a bara box on it
Old Feb 21, 2010 | 06:48 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
If you ask MSD to do a chip for a 7.5:1 engine and you get a couple of cracks of det then use the octane switch to take a couple degrees of ignition out. You arent going to be that far off the mark with your c/r are you. Not like its going to be 8:1 and you are thinking its 7:5.1.
Old Feb 21, 2010 | 06:59 PM
mattman1234
yep,never thought of that,how much difference does it make having the valve cutouts on cr,assuming all other aspects are the same
Old Feb 21, 2010 | 07:04 PM
J1mbo's Avatar
J1mbo
B1mbo
iirc valve cut outs make 0.2 difference
Old Feb 21, 2010 | 07:09 PM
mattman1234
mine have the valve cutouts done,and the dishes are very slightly bigger,compared to my old pistons,but only slightly bigger
Old Feb 21, 2010 | 07:12 PM
mattman1234
the grove did all the running round,great blokes,just mega busy
Old Feb 23, 2010 | 05:20 PM
mattman1234
phoned up today,def 7.5.1.
what sort of power should i expect t34.38 ?
Old Feb 23, 2010 | 05:23 PM
CossieRich's Avatar
CossieRich
A realistic 360 - 370 bhp i reckon.
Old Feb 23, 2010 | 05:43 PM
mattman1234
that would do for me, in a 750kg car
Old Feb 23, 2010 | 05:44 PM
mattman1234
Old Feb 23, 2010 | 05:47 PM
CossieRich's Avatar
CossieRich
I would say that is plenty yes mate
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
