efi management question. frst engine in 3i cab
Old 07-01-2005, 03:31 PM
skeld
skeld's Avatar
Default efi management question. frst engine in 3i cab
what needs to be done to run the efi 3i cabby management on the frst engine? we are in the middle of dropping the engine in and need to know what to do with the wiring. ive heard you just have to change a couple of pins over on the ecu connector and use an frst ofab ecu?
any help please, got to finish this weekend.
cheers
skeld
Old 07-01-2005, 03:33 PM
CraigN
CraigN's Avatar
incorrect
you need to swap a few wires over and use the OFAC ecu
have a look on www.fiestaturbo.com in the forums there is info in there i think
the efi cab uses same management as xr2i
Old 07-01-2005, 03:34 PM
Ginge !
just finding my feet
Ginge !'s Avatar
speak to alexzvhcabrio matey as he does this conversion alot
Old 07-01-2005, 03:43 PM
skeld
skeld's Avatar
I dont suppose you have the link to the msg on the fiestaturbo.com site?
Old 07-01-2005, 03:48 PM
CraigN
CraigN's Avatar
no
lazy bastard
Old 07-01-2005, 03:51 PM
M Brian
M Brian's Avatar
lol...
project al website isnt working at the mo.
when it is... there is a guide on there its... like duyu.co.uk or something
search for username project ST on here or ask for al on ft.com
chrissie (ragtop on here) wrote the guide for him I think. and is probably THEE best person to speak to about it
skeld
skeld's Avatar
ok found it now any way. weve got an ofab ecu, which one is better ofab or ofac?
Old 07-01-2005, 04:05 PM
Sexy-RS
Sexy-RS's Avatar
Use ofab
Old 07-01-2005, 04:12 PM
skeld
skeld's Avatar
to use ofab do i need a cossie map sensor?
Old 07-01-2005, 04:14 PM
Sexy-RS
Sexy-RS's Avatar
The map sensor you use will depend on what injectors / power ect you will be running / What your tuner advise's you
Old 07-01-2005, 04:16 PM
skeld
skeld's Avatar
at the moment just need to get it running. will only be using the standard injectors. about 12 psi boost. just use the standard efi map sensor?
Old 07-01-2005, 04:21 PM
Sexy-RS
Sexy-RS's Avatar
Then just a standard frst one would be fine, i don't think you can use the xr3i one somthing to do with boost i may be totally wrong i dunno they may be the same lol Best ask someone in the know
Old 07-01-2005, 04:24 PM
skeld
skeld's Avatar
cheers ppl
Old 07-01-2005, 04:50 PM
CraigN
CraigN's Avatar
faye ofab is a lot harder to fit than ofac
it maybe better for somethings (i know ahmed prefers is) but ofac is a plug and play with a couple of pin swaps
you will need a FRST map sensor anyway whatever you choose a 3i map sensor cannot register any boost only vacum
ask Stu and kenny what they think about ofac
Old 07-01-2005, 04:51 PM
CraigN
CraigN's Avatar
oh and melv a guy named andy wrote the guide he hada 1.8 zvh in a dark blue cabby someone on here bought it off him used to live im romford has a black focus i think now
Old 07-01-2005, 04:55 PM
skeld
skeld's Avatar
aparently to fit ofab, according to0 the guide on fiesta turbo.com it doesnt look like you have to do anything. it shows you how to convert the loom to ofac, then from ofac to ofab and it is just putting it back to how you started apart from modifying a few pins on a cossie map sensor.
here :
Converting an 8v 2i loom to OFAC
1) At the ECU, pin no. 27 (marked on the multiplug, brown wire) needs moving to pin 8, which is empty (this is the CO adjuster signal wire).
2) Pin no. 45 (brown/yellow) needs moving to pin 27 - this is for the MAP sensor.
3) EDIS Module pin 2 (blue/yellow) may now be disregarded as it is not used by the 0FAC ECU (pin 28 on ECU).
There are no MAP sensor pin changes as the OFAC MAP sensor is the same plug as the 2i MAP Sensor, so just plug and play.
Converting an OFAC loom to OFAB
1) Pin no. 8 (brown) needs moving to pin 27, which is empty (CO adjuster signal wire)
2) Pin no. 27 (brown/yellow) needs moving to pin no. 45
3) EDIS Module pin 2 (blue/yellow) may now be disregarded as it is not used by the 0FAB ECU (pin 28 on ECU).
MAP Sensor re-wire:
At the MAP sensor multiplug...
1) Move the brown wire (gnd) to cossie MAP sensor pin no. 1 (marked on multiplug).
2) Move the brown/trace* wire (feeds back to ECU on pin no. 26) to cossie MAP sensor pin no. 2
3) Move the brown/yellow wire (feeds from pin no. 27 on the ECU) to cossie MAP sensor pin no. 3
4) On one of the Cossie MAP Sensors fixing holes there is a metal ring which goes into the sensor. This ring must be earthed, and when you mount the Cossie map sensor using the right brackets, it connects to earth. (You should only ever mount the Weber/Cosworth MAP sensors with the vacuum pipe pointing downwards).
OFAB to OFAC
Revert back to (OFAC) with these pin changes on the MAP Sensor. These changes assume you have the MAP sensor sitting with the part code (stamped in the side of the sensor) and plug locking latch facing you.
1) Move Cossie MAP pin no. 1 to pin no. 3 (brown).
2) Move Cossie MAP pin no. 2 to pin no. 1 (brown/trace*)
3) Move Cossie MAP pin no. 3 to pin no. 2 (brown/yellow)
* brown and trace denotes any colour trace as i have come across many colours but usually it is either a green or a black trace.
Old 07-01-2005, 04:58 PM
Wazzzer
Wazzzer's Avatar
you can convert the loom to either OFAB or OFAC with the pin swaps
The info is fiestaturbo.com somewhere...
*skeld beat me to it as I'm too slow at typing*
Old 07-01-2005, 05:30 PM
CraigN
CraigN's Avatar
didnt know that :blonde:
EoinXR3
07-09-2015 05:44 AM
bigryrs
Fiesta RS1800/RS Turbo
05-09-2015 02:57 PM
Marcus L
29-08-2015 02:18 PM
bigryrs
28-08-2015 05:32 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: efi management question. frst engine in 3i cab
