quick question re pedal boxes
Old Feb 10, 2010 | 09:01 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
Default quick question re pedal boxes
am i right in thinking the smaller the master cylinder 0.ect the higher the pressure ?
ie a .625 mc is more powerful than a .700
if you get me , was having a discussion the other day and a mate belives its the opposite ,
beef
Old Feb 10, 2010 | 10:06 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
smaller moves less fluid,but at a higher pressure.
Old Feb 10, 2010 | 10:32 PM
The Youth.'s Avatar
The Youth.
you need to match the master cylinder size with the braking system front and back, I did on the 100E back in the day as I went from drums all round to ap 4pots on the front and 9 inch drums on the back lol
basically bigger pistons (in the calipers) need more fluid to fill the cylinders so you need to push more in there with a bigger master cylinder not the same amount at a higher pressure, if you get my drift
steve
Old Feb 10, 2010 | 10:45 PM
COLEYST200's Avatar
COLEYST200
is it for brakes or clutch you needit for mate
Old Feb 11, 2010 | 03:05 PM
-beefy-'s Avatar
-beefy-
my willwood setup came with two .625's and a .700
i planned on using the 700 for the hydro clutch and the two .625's for the fronts and rears , with a bias vale in the car for small adjustments once the pb is set up
beef
Old Feb 11, 2010 | 04:39 PM
COLEYST200's Avatar
COLEYST200
Im using the 700 for the hydro clutch on my 3dr
Old Feb 12, 2010 | 12:24 AM
NUTS RuS's Avatar
NUTS RuS
beef
Front and rear pressure same ? Crazy man lol
Old Feb 14, 2010 | 08:10 PM
-beefy-'s Avatar
-beefy-
well like i said tony im not 100 % sure on the setups , ive never had one before
if you could shed some light or advice id appriceate it ,
beef
Old Feb 14, 2010 | 08:12 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
im doing mine as we speak. wish i never started
Old Feb 14, 2010 | 08:40 PM
Lloyd's Avatar
Lloyd
i used 6.25 for the front and 7.0 for the rear.worked quite well with the bias bar set up
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
markk
Sep 9, 2015 08:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Rizlablue
Sep 6, 2015 10:54 AM
Rizlablue
Sep 6, 2015 09:58 AM
