adjustable boost
Old Feb 10, 2010 | 08:54 PM
rs-tuner's Avatar
rs-tuner
Cool adjustable boost
im after fitting an adjustable boost controller to my mk1 frs.can anybody tell me whats the best one to get. how hard they are to fit and if i will have any problems running one cheers.
Old Feb 11, 2010 | 09:26 AM
rs-tuner's Avatar
rs-tuner
Anyone
Old Feb 11, 2010 | 09:35 AM
DaveZS's Avatar
DaveZS
Better use my strong hand
I've got an apexi avcr on my 200sx. Nice bit of kit. For a cheaper one that people also rate, check out the profec spec b.
Not hard to fit, just make sure you follow the steps in setting it up.
Old Feb 11, 2010 | 10:07 AM
JokerDisco's Avatar
JokerDisco
Why pay money for adjustable boost when you can make one yourself for a fraction of the costs????
You only need to interupt the amal valve signal to the ECU and it will then get lowered by the ECU.
Granted, its not adjustable as such but it still gives you the option of a two stage boost - Good enough for motorway or chilled out driving.
All you need is an Amal valve with the three tubes connected up, some jucntions blocks, some half decent insulated wire and a switch - al lthis for under a tenner!!!
Mine works perfect.
*****Ignore my above comments I read your post wrong, thought you were looking for two stage boost*****
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Fezman1
Oct 2, 2015 01:22 PM
Russ Payne
Sep 25, 2015 08:29 PM
