Siemens injectors low/high imp
Old Feb 6, 2010 | 11:17 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Default Siemens injectors low/high imp
Im wanting to fit siemens 55lb injectors to my stg 3 cossie what does impedance mean and what is the difference between high and low impedance?
Old Feb 7, 2010 | 02:44 PM
Impedance, means sort of resistance in easy terms.
High impedance injectors put in place of a ecu that runs low impedance ones normally will have a much harder job to run these and might damage the ecu.
A ecu that needs high then used with low is likely to overheat the injectors(don't ask me how I know!!)
Low are around 2-5 ohm, high around 12-15 ohm, roughly.
Old Feb 7, 2010 | 03:21 PM
rich123's Avatar
rich123
ummm didnt know that,so how do u determine which ones u have pust a tester on the injector plug?
Old Feb 7, 2010 | 03:25 PM
rich123's Avatar
rich123
just been reading up on mine i use mjy100460 injectors the are 15.6 ohm high impedance and a flow rate of 480cc i got them out of a rover vitesse 30 quid i think i payed for all 6 of mine
Old Feb 7, 2010 | 05:08 PM
kidsRS's Avatar
kidsRS
How do i know which ones i need?
Old Feb 7, 2010 | 05:23 PM
rich123's Avatar
rich123
you would have to try and find out what injectors are in urs now and then find out if they are high or low impedance i guess
Old Feb 7, 2010 | 06:33 PM
LHD220Turbo's Avatar
LHD220Turbo
for a cossie, you need low imp 2.8ohms
Old Feb 7, 2010 | 06:37 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
That flow rate sounds high, was it a Vitesse as in V8?
Checking for impedance is very easy, just use a multi meter.
Old Feb 7, 2010 | 06:48 PM
As above just test a std one, then get whatever sort you need, if you need high but have low, you can always use a resistor in the earth line to make it high impedance.
Old Feb 7, 2010 | 06:51 PM
rich123's Avatar
rich123
no staderd rover vitesse 2.0
Old Feb 7, 2010 | 06:57 PM
Martin-Hadland
The flow rates sound high for a std Rover injector fitted to a circa 200hp (turbo) 4 pot, maybe worth getting them checked?
Old Feb 7, 2010 | 07:04 PM
Stu @ M Developments's Avatar
PassionFords Creator
These are the ones for your cosworth if you are still running on Weber OE management.
Old Feb 7, 2010 | 07:43 PM
kidsRS's Avatar
kidsRS
Thanks people!
Stu can any tuner that can map cars reprogramme my msd chip to the spec of my car?
Old Feb 7, 2010 | 08:47 PM
rich123's Avatar
rich123
i have cheked them out i was supprised when i found out abd had the car mapped the other week and no probs there,they also use them in the mini mpi and a few other cars http://www.theminiforum.co.uk/forums...p/t107172.html
heres 1 link i did find an info link about these injectors ill see if i cant find it
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
cos elle
Sep 16, 2015 06:37 PM
