welding experts!!!!!!!
Old Feb 6, 2010 | 01:36 PM
ybturbo's Avatar
ybturbo
Default welding experts!!!!!!!
Hi all!!! I need to install an external wastegate to my car but I don't like to use s/s exhaust manifold because it is not durable. I need to keep my standard 4wd cast one but I'd like to know which is the best and most durable way to weld a pipe (and also what kind of material for the pipe) on the manifold? Also what would be best; MIG, TIG or ARC? Also is it better to weld it preheated or cold? Cheers!!!
Old Feb 6, 2010 | 01:41 PM
muz's Avatar
muz
Wye Valley Hardcore
Welding to cast is never a good idea really. It will need to be pre heated, and welded in very small sections at a time. Chances are though on a manifold egtting so hot it will just crack anyway later on.
Old Feb 6, 2010 | 01:50 PM
ybturbo's Avatar
ybturbo
I get your point... I saw it somewhere by the way but if not durable then not good for me... That's the reason that I dont like to use s/s manifold...
Old Feb 6, 2010 | 01:55 PM
muz's Avatar
muz
Wye Valley Hardcore
If the SS manifold is good qauilty and braced then it shouldn't be a problem. If you do have to weld cast I'd probably ARC weld it with a nickel rod on a low heat setting, but still not ideal.
Old Feb 6, 2010 | 02:02 PM
ybturbo's Avatar
ybturbo
ok thanks!
Old Feb 6, 2010 | 02:17 PM
Why not use a CAST rod to weld cast, no reason you can't, this is how I modded my front pulley when welding a steel trigger wheel onto it.
That said the heat will affect it, not likely in long term to last unless you use a LUMIWELD rod, the stuff is simply amazing, don't even need a welding set!!, just the rod and a heat source, eg blowtorch will do it, works on pretty much all metals.
Old Feb 6, 2010 | 03:05 PM
fraser9764's Avatar
fraser9764
why do you need an external wastegate? surely if you are on a standard manifold an internally gated turbo will be fine.
Old Feb 6, 2010 | 03:34 PM
xr4x4rs's Avatar
xr4x4rs
or just go 2wd manifold and get a a trouser part off reyland already done to accept a external wastegate
luke89's Avatar
luke89
Team HOTHOT!
does reyland not sell the convertion for this?
Old Feb 6, 2010 | 03:36 PM
crazycage's Avatar
crazycage
that would deffo be the best option imo
Old Feb 6, 2010 | 05:02 PM
scruffythefirst's Avatar
scruffythefirst
I'm just doing this at the moment. I don't have room for a 2wd manifold and need to do the wastegate piping myself. I'm going to mill a hole in the right place at the angle i need and then insert a mild steel tube. I'll tack it in place with a mig and mild steel wire and then take it to a welding shop who specialise in cast iron and get them to do it. From what I've read it needs pre heating and then cooling very slowly to stop it cracking. Mild steel should flex enough in use to stop it cracking, stainless would most likely crack. As the whole lot will be going to Zircotec it should be nice and rust proof when its ceramic coated.
Old Feb 6, 2010 | 06:26 PM
ybturbo's Avatar
ybturbo
The turbocharger internal one is unable to cope above 5500 rpm, the boost just rises as the revs rise and with w/g fully open! I'm on a stroker kit also...
I might think about that but space is a bit restricted...
That thing with the mild steel tube sounds good! The tube will flex and with good preheating and ideal cooling for anealing it should be fine...
The only problem is who on earth can do it here properly?
Old Feb 6, 2010 | 06:50 PM
Garage19's Avatar
Garage19
Sorry but you are such a cock. Have you ever used a lumiweld rod?
I guess not or you would know they are for welding aluminium (hence the name) and not cast steel / iron alloys.
Not to mention the fact that they are shite.
I can't stand people who give out advice on something they have no idea about.
Old Feb 9, 2010 | 07:24 PM
scruffythefirst
Now my wastegate has turned up and I can see what angle I need the pipe inserting at, I'm having a problem getting the hole machined. None of the machine shops round here have a 45mm slot drill (unsurprisingly), cnc time is expensive and will take ages as no-one has any spare capacity.
For the cost of the machining I could buy a slot drill and have access to several different mills. At this rate I could just buy a cheap stainless manifold!
Old Feb 9, 2010 | 07:50 PM
Isaac.Hunt's Avatar
Isaac.Hunt
Why do you need a 45mm slot drill? Just use whatever size smaller than 45mm is available and machine the hole to size.
Absolutely every machine shop is going to have a 10mm or 20mm slot drill knocking about.
Old Feb 17, 2010 | 07:44 PM
scruffythefirst
Ignore the quality of the welding, there aren't any leaks.
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
