ARP rod bolts.
Does anyone know if these can be re-used? or do they stretch to much to be safe to use again? its for a 1.6 zetec se if that makes any difference, cheers.
ARp rod bolts can be used again...
You are meant to measure them at first use, then remeasure them when they are removed and compare the results to the spec ARP give you with the bolts, if theyre still within spec you can use them again.
