Master Cylinders ERST
Right i have the same problem as everyone else. I have a "25" Master Cylinder and its started weeping from the rear i know you cant get parts for them or the cylinders themselves, but what i need to know is can you use the 22 or 23 cylinders with the rst servo and also if they will be ok to use with my brake set-up, standard rears and cossie 4 pot fronts?
I dont think you can still get the rebiuld kits for the original 25mm bore cylinders I know you can get them for the 23 and 22mm ones but ill need to buy a new cylinder anyway
Mc5506
05-10-2015 09:57 PM
