engine management
Old Jan 28, 2010 | 06:40 PM
THE RADMAN's Avatar
THE RADMAN
Default engine management
the engine management light came on today on my lads fiesta [2000, 1.25] and started flashing,it turned out to be the coil pack so i fitted a new one and it runs fine and the lights stopped flashing,however it is still lit up constantly,does this mean another fault? it drives fine now
Old Jan 29, 2010 | 04:29 PM
THE RADMAN's Avatar
THE RADMAN
anyone? does it just need clearing now the faults been repaired? i know bugger all about fiestas
Old Jan 29, 2010 | 05:31 PM
:hEnNiKeR:'s Avatar
:hEnNiKeR:
Bam Bam Bam
yeah usually: management light comes on, fault code reader diagnoses the fault, fix fault, clear fault codes.
if the management light comes back on then there will be another fault but usually the initial fault code read should pick up all the faults in the system?
hth.
Old Jan 29, 2010 | 05:52 PM
MarkyMark's Avatar
MarkyMark
disconnect the negative battery lead for 15 mins and branch onto the postive once will reset the fault codes
Old Jan 29, 2010 | 06:27 PM
THE RADMAN's Avatar
THE RADMAN
what do you mean by branch on the pos?
Old Jan 29, 2010 | 07:08 PM
MarkyMark's Avatar
MarkyMark
tap negative lead onto postive lead
jay030787
Sep 18, 2015 07:34 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Old ford
Jul 31, 2015 06:50 AM
