Changing bulbs to LED's
Hey guys,
As above really, i'm sick of the bulbs blowing all the time on my transit connect, and was wondering if its at all possible, and if so where would i get them from??
I'd be looking to change the brake/rear light bulbs, number plate bulbs, indicators all round, then putting a HID kit on the headlights,
If anyone has done this or has info it'd be greatly appreciated.
CheeRS
Barry
CheeRS
Barry
Got HIDs on my connect and LED for the number plate will be fitted in the next week or so.
If you keep blowing bulbs, I'd go looking elsewhere for the problem. Connects aren't known for regular bulb failure
I would check other things as well first.
LED's will blow VERY VERY easy if too much voltage, or current(ma), they obviously will come with in built resistors but these will only be any good for the value used in working out the resistor rate needed, I always work out with 13.5 volts, but even going to 14.5 is likely to pop them.
If still wanting though have a look on www.dealextreme.com
dont waste your money on Hid kits i got a set for my transit loved them to start with but one bulb stopped working the ballest box had packed in, like said loved them at the start but had to stop every now and then to clean the lenses just get some good bulbs, just as good imo
07-10-2015 12:56 PM
Steve Escos
01-10-2015 06:57 AM
rsguy
44
29-09-2015 03:29 PM
