ECos Diff Gearbox Transfer box
Old Jan 5, 2005 | 07:28 AM
rsdene's Avatar
rsdene
Default ECos Diff Gearbox Transfer box
Hi
can someone tell me the capacities and what fluid to use in the transfer box gearbox and diffs ?????? how often should they be changed??
cheers
Old Jan 5, 2005 | 08:18 AM
gearboxman's Avatar
gearboxman
Rear diff iro 1.75L SS75W/90 or EP80W/90
Front diff 1.3L SS75W/90 or EP80W/90
Gearbox 2.4L MT75 fluid
Transfer 0.5L Dexron 2
There are no drain plugs on the diffs, so you would need to remove the covers on each. Probably least in need of oil change.
Gearbox is a real good idea to change the oil on, as the MT75 fluid gets very dirty (probably high detergent level).
Not a bad idea to change the transfer oil. Drain this into a clean container. If there is any evidence of a grey sludge then your VC is losing fluid.
Old Jan 5, 2005 | 08:28 AM
rsdene's Avatar
rsdene
Lovely thanx alot gearbox cheers again
TPM961
Jan 15, 2018 10:50 AM
yatta
May 21, 2016 10:31 PM
155lee
Oct 27, 2015 04:55 AM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
