General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I know it doesnt actually work any better but it looks a million times better as you dont get that horrible 1" rusty bit round the outside of the bells
so basicaly youve got no more clamping force with these ?
Correct! no more clamping force as you are still using your caliper. But because the diameter is 25mm larger you get better braking as the radius of the disk is bigger.
i see what your saying, excuse me for being stupid
Ive just had a set of these deliverd today along with some 6pots for front - cheers martin. how much would bigger calipers cost for the back out of interest? if there is any that work with the discs you sent me today.
I see... I have done a search and I discovered a setup from HiSpec with 4piston calipers and handbrake levers... It's a lot more pricy but I believe with much better results... Maybe I should start thinking about that and it has got more disk sizes available... Thanks guys for the info!!!
