1997 escort gti emissions fail! is it likely to be lambda sensor?
Old 18-01-2010, 12:55 PM
M K
M K's Avatar
Default 1997 escort gti emissions fail! is it likely to be lambda sensor?
just took my 1997 5 door escort gti for its mot, new it was gonna fail as it needs a bit of welding but get a free re test so thought id see what else it needs before work commences lol,
well it failed the emissions and the tester said it could need a new lambda sensor causing high emissions! and also the car if
dle really lumpy then smooth then lumpy on and off all the time?
before i just buy and fit a new sensor is there any other common faults on these that could be the cause to check as well?
thanks marc
Old 18-01-2010, 12:58 PM
**caz**
**caz**'s Avatar
when was the last time the air filter was changed?? air filter can cause problems and yes also the lambda sensor! had this myself!
also get it red hot before you take it in..having it boiling hot helps it go through too
x
Old 18-01-2010, 01:05 PM
M K
M K's Avatar
the temp gauge doesn't work
but it was sat idling for fooking ages before the test and he left it another 20 mins after it failed to try again, as for the air filter i have no idea and have not even bothered to look but will do
Old 19-01-2010, 01:40 PM
M K
M K's Avatar
x
checked the air filter today...................................
suppose it would help if there was one in there
bought one to fit tomorrow
Old 19-01-2010, 01:50 PM
wirralphil
wirralphil's Avatar
disconnect the maf, if the idle runs ok then change that.
If not the idle control valve could do with a clean.
As caz says change the filter or add one lol as this makes a difference, as for the lambda buy one from the scrappy for a £10 and they that before you retest.
Old 19-01-2010, 02:02 PM
M K
M K's Avatar
got a second hand lambda for £12, will fit the new air filter as well and a new thermostat as the cars not getting up to temp properly so gonna do that for the sake of a few quid too,
as for the idle, disconecting the MAF does nothing so i will give the iscv a good clean up and re fit
thats the easy bit, gotta deal with this little lot after that
complete new rear chassis sections for both sides turned up today tho so a busy Saturday ahead
Vincereese
01-06-2023 09:14 AM
FlashRS
14-09-2015 12:36 PM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
Quick Reply: 1997 escort gti emissions fail! is it likely to be lambda sensor?
