Help please!!!!!! Power steering problem WTF?????
Old Jan 4, 2005 | 04:27 PM
Disabled Account's Avatar
Disabled Account
Default Help please!!!!!! Power steering problem WTF?????
Can anyone identify this power steering problem on a friends
Escort Cossie:
Driving down the road in a straight line - FINE no problem, feels perfect
As soon as you put some lock on (even if only a few degrees) there is a VERY bad vibration/judder at the steering wheel.....This also happens (with lock on) at parking speeds (2 MPH)......
Also the steering pump is whining
It it MOST likely to be the PUMP or the STEERING RACK??????
Old Jan 4, 2005 | 04:34 PM
MikeyXR2i's Avatar
MikeyXR2i
Sounds like no fluid or air in it.
Old Jan 4, 2005 | 04:36 PM
Graceland's Avatar
Graceland
Team HOTHOT!
check the inner tca bushes for the vibration - as for the fluid and whining pump, check the fluid viscosity - if its to thin it wont be as effective as it's supposed to be
Old Jan 4, 2005 | 04:38 PM
RichardPON's Avatar
RichardPON
I was thinking no fluid, but I'd reckon Doug would have checked that!
Old Jan 4, 2005 | 04:41 PM
CraigN's Avatar
CraigN
sounds like a loose belt to me tighten it up
if it still does it maybe a fooked pump steering rack causing pressure i the system
Old Jan 4, 2005 | 09:48 PM
Disabled Account
BTTT............Update:
Thanks for replies so far, fluid level is fine......
Could a badly freyed (spl) belt cause the above symtoms?????
Belt was tight, but is very poor condition, edges damaged, lots of cracks.
Old Jan 4, 2005 | 09:55 PM
ECU Monitor Enthusiast
Sounds like a drive shaft problem to me !
Old Jan 4, 2005 | 10:08 PM
Disabled Account
Simon it is deffo NOT a drive shaft problem, as when you are manovering at very low speeds with lock on (2 to 4 mph) the front wheels AND steering wheel are juddering/oscillating quite badly
Old Jan 4, 2005 | 10:12 PM
Doug, Drive shaft could still do this, even at slow speeds.
One idea is to REMOVE temporarily the drive belt so the power steering does not work.
Then try a few slow manouvers just to see if its still there.
BEWARE - Only run the engine for a max of 30 seconds - 1 minute as the
water pump and alternator will not be running as the escort cos uses one belt for all.
Old Jan 4, 2005 | 10:19 PM
tonypastie's Avatar
tonypastie
tca/ front bush movement had it on a saff of cheeseman put new pollys in sorted !
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
slammedorion
15
Nov 1, 2015 07:17 PM
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
